http://auszookers.com/forum/
Need a Jimny Under Dash Fuse Box Diagram
http://auszookers.com/forum/viewtopic.php?f=5&t=31184
Author:  jim_dover [ Wed Mar 14, 2012 10:12 pm ]
Post subject:  Need a Jimny Under Dash Fuse Box Diagram
I am chasing a fuse block diagram for a 2004 Jimny. The fuse box thats under the dash. If an one could help i would appreciate it greatly.
Author:  jimny_timmy [ Sat Mar 17, 2012 8:16 am ]
Post subject:  Re: Need a Jimny Under Dash Fuse Box Diagram
Do you just want what's in the cover if the fuse box because you've lost it or you want a diagram of where the wires run to?
Author:  jim_dover [ Sun Mar 18, 2012 7:17 pm ]
Hi i just need a picture of the fuse box cover as I have lost it.
Thanks
Author:  squibby [ Mon Mar 19, 2012 8:51 am ]
I have diagrams/Fuse layout for all Jimnys. You need to be more specific though. Is it non-VVT 2004 Jimny? If so I think there is two types, Does it have small mini blade fuse box, or is the Large Blade Fuse style Fusebox?
Large blades being like approximately 2cm across the top (the common type) and small fuses being the same thing but about 1cm
Author:  jim_dover [ Mon Mar 19, 2012 3:30 pm ]
its a non-vvt jimny and has the large blade fuses.
Thanks
Author:  squibby [ Tue Mar 20, 2012 7:19 am ]
If these aren't the ones, then let me know your vin number (pm it to me) and I'll post up the right ones. I think these should be correct though.
