| Speedo for roadworthy http://auszookers.com/forum/viewtopic.php?f=5&t=31186 |
| Author: | Bombero [ Wed Mar 14, 2012 10:34 pm ] |
| Post subject: | Speedo for roadworthy |
I remember a few years ago in Vic a taco was good enough in place of a speedo. Is this still the case? I bought a new speedo cable because it was broken but as I put it in I noticed the little lug in the transfer is broken off. I really don't want to split the case to fix it. So will just the taco pass? |
| Author: | JrZook [ Wed Mar 14, 2012 10:48 pm ] |
| Post subject: | Re: Speedo for roadworthy |
In a sierra tcase you dont have to split it to replace the drive gear. Get a new gear, spend 5mins under the vehicle and done. No worries then with your speedo and a roady. |
| Author: | BlueSuzy [ Wed Mar 14, 2012 10:59 pm ] |
Yes, Undo the bolt and it should pull out..if its broken off its going to be a pain.. Some people have trouble with them even with the lug to grip and pull out.. |
| Author: | buzbox [ Thu Mar 15, 2012 8:22 am ] |
mmm Taco's. As you may know, Tachometer's only indicate the revolutions per minute / hour of the engine (depending how many zero's are on teh tacho) not speed. I'm not 100% certain of the rules reg's in Vic, but I would say it is very unlikely that it would be legal to use a tacho as a speed indicator in any state or territory in aus. |
| Author: | 31zook [ Thu Mar 15, 2012 9:03 am ] |
I went for Rego without a speedo once.... I was so use to it I had forgotten about it till after It passed and I was driving home... |
| Author: | want33s [ Thu Mar 15, 2012 9:58 am ] |
Speedo IS a requirement for compliance but the chances of a not working speedo being picked up during the inspection are slim if the car is unregistered because it can't be test driven unless the garage has a trade plate. |
| Author: | Bombero [ Thu Mar 15, 2012 10:30 pm ] |
So if I pull the speedo cable out that that little peice with the lug should pull out? Thanx for all the replys |
| Author: | foolsp33d [ Fri Mar 16, 2012 6:28 am ] |
Yep! ![]() ![]() http://zukiworld.com/month_070102/featu ... nstall.htm ![]() http://blogpdf.com/suzuki-samurai-6.5-t ... it-4970110 |
| Author: | Bombero [ Fri Mar 16, 2012 6:33 am ] |
Wow. Thanx for the detail. Where abouts can I get a new one of those? |
| Author: | BlueSuzy [ Fri Mar 16, 2012 6:39 am ] |
Put up a wanted post, someone might have one spare, or try wreckers. Unsure if they can be bought new? |
