| want to buy turbo for 1993 sj70 sierra http://auszookers.com/forum/viewtopic.php?f=5&t=31284 |
| Author: | sj70zuki [ Tue Mar 20, 2012 10:41 am ] |
| Post subject: | want to buy turbo for 1993 sj70 sierra |
where can i fine a turbo for 1993 sj70 sierra and how much it will cost |
| Author: | atari4x4 [ Tue Mar 20, 2012 11:05 am ] |
| Post subject: | Re: want to buy turbo for 1993 sj70 sierra |
$200 band new turbo 5 minutes to go. http://www.ebay.com.au/itm/new-universa ... 3a71bcf087 |
| Author: | abclarke [ Tue Mar 20, 2012 11:14 am ] |
Is this for a 1.3? Why not go a 1.6 and go from there? |
| Author: | Fatzook [ Tue Mar 20, 2012 11:26 am ] |
Aldi sell some good turbos. |
| Author: | Gwagensteve [ Tue Mar 20, 2012 11:36 am ] |
Electric supercharging is even better. Leaf blowers are excellent too. Steve. In all honesty, turbocharging a g13 is very costly and normally results in broken motors. The turbo is the cheap bit. If you need to ask how much a turbo is, you're not ready to start going down this path. If you can't fabricate, wire, and are good with cars, figure on about $6k. |
| Author: | abclarke [ Tue Mar 20, 2012 11:40 am ] |
Fuck for 6k I'd rather something other than a 1.3 |
| Author: | Daves4wd [ Tue Mar 20, 2012 6:13 pm ] |
I've got a mate selling a turbo kit for 1200 it's for a gti 1.3 is be guessing it's the same but you need a injection set up got kit had his front wheels in the air hahaha on of you want more info |
| Author: | Gwagensteve [ Tue Mar 20, 2012 6:28 pm ] |
So lets use that as an example. (and no offence Dave - it might be a great kit, but you've provided no information so I'll speculate for the sake of my argument) $1200 for the kit. $800 for a GTI motor? Fuel system? Wiring loom? Engine Management? Clutch? Dyno Tuning? Depending on what's included in the $1200 "kit", and assuming that the turbo itself is in good nick, there's still, what, at least $4K between now a running GTi engined turbo sierra? What if the GTi motor needs a rebuild? What if the turbo needs a rebuild? What if it turns out to need a smaller turbo which requires new piping flanges, dump pipe etc (and this is common- over-turboing is everywhere in "conversions") Really, it's all a terribly expensive and complex business when it's likely a G16B has plenty of power and torque to fix whatever problem you were trying to fix with the turbo in the first place, unless you really just wanted hektik choof and spool noises. Steve. |
| Author: | royce [ Tue Mar 20, 2012 6:49 pm ] |
This is my new why you dont need a turbo answer ![]() This drives over stuff you likely never will, but has less power than my Vitara |
| Author: | SierraDan [ Tue Mar 20, 2012 6:58 pm ] |
and The hazzard zook has a 4k carby motor. i've only ever wanted a 1.6 EFI for highway use. |
| Author: | atari4x4 [ Tue Mar 20, 2012 7:01 pm ] |
but it doesn't make mad flutter or dose (what ever that means) |
| Author: | stockman [ Tue Mar 20, 2012 7:03 pm ] |
royce wrote: This is my new why you dont need a turbo answer ![]() This drives over stuff you likely never will, but has less power than my Vitara What motor is in it? |
| Author: | SierraDan [ Tue Mar 20, 2012 7:09 pm ] |
atari4x4 wrote: but it doesn't make mad flutter or dose (what ever that means) From what i've figured. its when you dont have a blow off valve. so the air goes back through the turbo and flutters as it hits the turbine again. so basically its the sound of your turbo gradually failing haha. |
| Author: | Fatzook [ Tue Mar 20, 2012 7:29 pm ] |
stockman wrote: royce wrote: This is my new why you dont need a turbo answer ![]() This drives over stuff you likely never will, but has less power than my Vitara What motor is in it? G13BB |
| Author: | abclarke [ Tue Mar 20, 2012 7:40 pm ] |
SierraDan wrote: atari4x4 wrote: but it doesn't make mad flutter or dose (what ever that means) From what i've figured. its when you dont have a blow off valve. so the air goes back through the turbo and flutters as it hits the turbine again. so basically its the sound of your turbo gradually failing haha. Haha stupid rice burners/wog boxs. Probably a mechanic or turbo salesman started that trend as an easy way to make cash |
| Author: | royce [ Tue Mar 20, 2012 8:03 pm ] |
Fatzook wrote: stockman wrote: royce wrote: This is my new why you dont need a turbo answer ![]() This drives over stuff you likely never will, but has less power than my Vitara What motor is in it? G13BB The little honda engine on the water blaster was lined up if we needed a replacement engine whilst down there
| Author: | monley [ Tue Mar 20, 2012 8:06 pm ] |
abclarke wrote: SierraDan wrote: atari4x4 wrote: but it doesn't make mad flutter or dose (what ever that means) From what i've figured. its when you dont have a blow off valve. so the air goes back through the turbo and flutters as it hits the turbine again. so basically its the sound of your turbo gradually failing haha. Haha stupid rice burners/wog boxs. Probably a mechanic or turbo salesman started that trend as an easy way to make cash Or you could just get the i-fail app and connect it to your car doof doof
| Author: | atari4x4 [ Tue Mar 20, 2012 8:13 pm ] |
^^^ and thats the end of this thread
| Author: | abclarke [ Tue Mar 20, 2012 8:30 pm ] |
monley wrote: abclarke wrote: SierraDan wrote: atari4x4 wrote: but it doesn't make mad flutter or dose (what ever that means) From what i've figured. its when you dont have a blow off valve. so the air goes back through the turbo and flutters as it hits the turbine again. so basically its the sound of your turbo gradually failing haha. Haha stupid rice burners/wog boxs. Probably a mechanic or turbo salesman started that trend as an easy way to make cash Or you could just get the i-fail app and connect it to your car doof doof ![]() Got one in the jimny? |
| Author: | monley [ Tue Mar 20, 2012 8:40 pm ] |
Nup, don't have a i-fail |
| Author: | atari4x4 [ Tue Mar 20, 2012 8:45 pm ] |
i'm downloading the GReddy one now, will report back on the performance gains when i knock off work. should be hektik
| Author: | atari4x4 [ Tue Mar 20, 2012 10:18 pm ] |
OMFG i had uncontrolable wheelspin in every gear. |
| Author: | SierraDan [ Tue Mar 20, 2012 10:25 pm ] |
did it dose bro? |
| Author: | atari4x4 [ Tue Mar 20, 2012 10:27 pm ] |
i think it dosed, but zero pigeon flutter. |
| Author: | JrZook [ Wed Mar 21, 2012 12:38 am ] |
SierraDan wrote: atari4x4 wrote: but it doesn't make mad flutter or dose (what ever that means) From what i've figured. its when you dont have a blow off valve. so the air goes back through the turbo and flutters as it hits the turbine again. so basically its the sound of your turbo gradually failing haha. Tis called turbo surge, where the compressor looses then grabs the air again. Not good at all. |
| Author: | atari4x4 [ Wed Mar 21, 2012 12:43 am ] |
Mad flutter pulls da bitches |
| Author: | Dr_Snapid [ Thu Mar 22, 2012 7:13 pm ] |
Either you guys have got turbos and blow off valves all wrong or I dont get your lingo LOL |
| Author: | atari4x4 [ Thu Mar 22, 2012 7:21 pm ] |
