| Author |
Message |
Mike
lesspostingmorewheeling
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
 Posted: Fri Oct 10, 2008 1:56 am |
i've got 2 zooks a WT with a standard case and an NT with trail gear 6.5s
what do i need to do to swap the cases over?
will the handbrake off the nt case fit the wt?
_________________ [quote="Fluffy"] yeah right mate like Im gunna mov
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Fri Oct 10, 2008 2:18 am |
the handbrake should swap over no hassles, you'll have to swap the flanges as well
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
Mike
 Posted: Fri Oct 10, 2008 2:19 am |
just_cruizin wrote: the handbrake should swap over no hassles, you'll have to swap the flanges as well
all three flanges?
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Fri Oct 10, 2008 10:11 am |
yes all , you need the nt flange to bolt onto the nt case. dont worry about the handbrake just use the ones on the in the car.
Mike
 Posted: Fri Oct 10, 2008 5:54 pm |
yeah i'm sticking with the handbrake on rear drum in the black one but i want to put the wt case back in the pink one so i need to put the handbrake back on it
Brett
 Posted: Fri Oct 10, 2008 7:18 pm |
i have a feeling that the wt case won't take the handbrake in it. not sure
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Oct 10, 2008 8:13 pm |
