Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
callanrj
Joined: Mon Jan 30, 2012 6:55 pm Posts: 4 Location: geelong
Vehicle: 1992 hardtop sierra
 Posted: Thu Mar 22, 2012 6:15 pm |
G'day all, im fairly new to auszookers and 4wding in general and iv been looking into buying some Sunraysia rims and ive found some that are 15" x 7" and the offset is +3P, -12N... im not to sure about what offset is and if the rims will suit my swb sierra with 2 suspension lift, and im still not 100% sure on what tiers i should get for this rims so im in need of some big help from all you experienced zookers!!
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13016 Location: Melbourne
 Posted: Thu Mar 22, 2012 6:18 pm |
Maybe you're starting around the wrong way? surely you'd choose rims to suit your tyres?
callanrj
 Posted: Thu Mar 22, 2012 6:34 pm |
Well i thought it will be better to get the rims first then finding a decent set of M/T for it other then my stock rims with all terrains on them, but if you think it will be better by doing it the other way round then maybe i should look in to doing that.
Thanks
Gwagensteve
 Posted: Thu Mar 22, 2012 6:40 pm |
It's only that offset is normally a function of the tyre size you intend to run - offset is really all about trying to prevent the tyres hitting the chassis/shock mounts etc.
at -13 the inside edges of the rims will be in the same position as standard, but the outside edges will be 37mm further out than stock.
at +3, the inside edges of the rims will be 17mm closer to the chassis, and the outside edges 21mm further out than stock.
Most people would recommend -13.
callanrj
 Posted: Thu Mar 22, 2012 6:56 pm |
Thanks this help allot! i think i might keep looking at the different rims sizes and see what i come across.
atari4x4
 Posted: Thu Mar 22, 2012 7:32 pm |
callanrj
 Posted: Thu Mar 22, 2012 7:46 pm |
cheers off been looking for a thread like this!
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 537 guests
