It is currently Mon Sep 21, 2026 11:51 am
Post Posted: Wed Apr 04, 2012 4:57 pm
Ive got a bit of a problem with my coily.
One minute it idles perfect and then about 10 Minuites later it idles really low or stalls.
Ive replaced Fuel Filter and Spark plug leads and turned up the idle screw but its still doing it.
Any ideas on fixing it would be much appreciated.
Post Posted: Wed Apr 04, 2012 6:11 pm
crap in the fuel bowl inside the carbie blocking the idle jet
Post Posted: Wed Apr 04, 2012 6:19 pm
Hole in the diaphragm of the accelerator pump
Post Posted: Wed Apr 04, 2012 9:03 pm
:shocked: You must use spellcheck!!!
Accelerator pump has no effect on idle though.
Post Posted: Fri Apr 06, 2012 5:58 pm
When it is idling low, try restrict the intake. If the idle comes back up you have a blocked Idle circuit, if not there is something a miss, common for them to block idle circuits though, can try the hand over the top or pull the mixture out and give it a blow.
Suzuki is my way of life.
Post Posted: Fri Apr 06, 2012 7:18 pm
i've had same problem. found a leaking inlet manifold gasket .
Post Posted: Wed Apr 11, 2012 5:50 pm
Thanks for the help. The hand trick did the job.
Post Posted: Fri May 11, 2012 4:43 pm
hey,
what is a idle crircuit because my car was doing the same thing and i did the hand thing and the idles incase
Users browsing this forum: No registered users and 143 guests
