It is currently Tue Sep 22, 2026 11:09 pm
Post new topic Reply to topic  [ 29 posts ]
Vehicle: '94 suzuki maruti
Post Posted: Sat Apr 07, 2012 10:13 am
4wding yesterday, coming back home along a dirt road, my car randomly stalled and wouldnt turn back on. The ignition coil/dash cluster fuse had blown, but when I replaced the fuse it was behaving as though the timing was way out...
i've tried redoing the crank/cam timing suspecting it had skipped a tooth... But I was going quite slow when it did happen, so now im thinking it must be something to do with the blown fuse. When I replaced it I used a 10a fuse instead of the 15a it says to use in case there was a short but its still intact... And I dont even know where to start looking, anyone able to give me an idea of what it could be??
Edit: should mention its a maruti, with a G13A engine.
Post Posted: Sat Apr 07, 2012 10:33 am
Dissy module?
Post Posted: Sat Apr 07, 2012 10:56 am
It is getting spark, gave me a lovely kick whiile checking that... Its just wierd because I was driving hard all day, we stopped to air up, drove another 10 or 15 mins before it happened...
Post Posted: Sat Apr 07, 2012 11:12 am
OK check the basics then..
Broken rotor button.
Arc'ing in the cap.
Dissy drive gear.
Post Posted: Sat Apr 07, 2012 11:29 am
tried replacing with (used but working) dizzy cap, rotor and leads, as well as coil... dissy does spin while engine is cranking over, but i'll pull it off to double check it when i get it home. gave up trying to repair it side of road so going to hire a car trailer now...
Vehicle: Sj70 tintop
Post Posted: Sat Apr 07, 2012 11:33 am
getting fuel to the carby?
Sj70 tintop
Post Posted: Sat Apr 07, 2012 11:36 am
yeah getting fuel, seems to be getting spark, thats what made me think timing in the first place. just didnt think it was coincidence that it blew a fuse just as it stopped working...
Post Posted: Sat Apr 07, 2012 12:06 pm
slipped a tooth, how hard were you giving it to it?
spose you need to pop the cover off and have a looksy when it gets home.
how does the oil look? any water involved in the days activities?
Sj70 tintop
Post Posted: Sat Apr 07, 2012 12:33 pm
i was driving quite hard during the day, enough for it to slip a tooth... however, after we were done i pulled up for about 20 minutes to air up & have a quick feed, and drove off. 10 or 15 mins later i stopped to play with some settings on the uhf, realised id stalled when i stopped and it wouldnt start again.
only water involved was half a foot deep at most, and not flowing at all. it was all sand driving for the day. the engine did get quite warm at one point while doing a sand dune, but i drove for a good 2 or 3 hours after that with no problems whatsoever...
i did take the cover off on the side of the road to try and redo the timing, but ive never done it before so i cant be 100% but i followed exactly what i read on here to do. even spun the crank round and tried again in case i had it 180 out, no improvement... i'll have a proper go at it when i get it home
Post Posted: Sat Apr 07, 2012 12:38 pm
sounds like something simple i hope.
Sj70 tintop
Post Posted: Sat Apr 07, 2012 3:20 pm
So do I haha. Doesnt sound like anything broken, but i'll pull the cover and dizzy off tonight.
Post Posted: Sat Apr 07, 2012 4:27 pm
Lemon seller Joel :roll:
Post Posted: Sat Apr 07, 2012 5:11 pm
I know right, that bastard!
haha nah shes been a good little rig, and I know this stuff just happens without warning. Its not something you could expect to happen when selling. Worst case scenario, I get the engine out of my old sierra and use that.
Post Posted: Sat Apr 07, 2012 6:01 pm
comming from you this hurts, as you share the same corrupt twisted DNA as christopher skase.
like a barrel of snakes you are paul. :roll:
Sj70 tintop
Post Posted: Sat Apr 07, 2012 6:03 pm
whincup wrote:
. Worst
piece of piss to do a rebuild on them, that carby will pop on any g13a/ba as well.
let me know how you go, hopefully its something simple.... like puals brain.
Sj70 tintop
Post Posted: Sat Apr 07, 2012 8:29 pm
Skase at least had morals. Not like your snake oil motor!
Post Posted: Sat Apr 07, 2012 8:49 pm
morals, suprised you dont top your pay up with the donation box on the counter of mcdonalds.... if its not nailed down.......
Sj70 tintop
Post Posted: Sun Apr 08, 2012 8:04 am
:lol:
Have a look on your coil. On the side closest to the fire wall there is a little black and brown plug that just sits on the hand barb on the coil. Has that come loose? It's not clipped on, it just pushes against it. Happened to me the other day. Worth a look.
Post Posted: Sun Apr 08, 2012 8:40 am
ok: stupid question time. ive just pulled the rocker cover off to see the valves... exhaust valve is the one on the exhaust side and intake valve is on intake side? if thats the case, then the exhaust valve has just finished closing when the cylinder fires... which is always awesome.
Post Posted: Sun Apr 08, 2012 9:07 am
so i went and checked it against my other car, appears the distributor is exactly 180 degrees out...
Post Posted: Sun Apr 08, 2012 9:53 am
yep. just put the leads on backwards (swapped 1 & 4, then 2&3) and she runs beautifully... very strange that it skipped exactly 180 degrees.
Post Posted: Sun Apr 08, 2012 9:59 am
VERY strange..... There MUST be something you have forgotten to tell us. Dissy's don't just jump 180 by themselves.
Post Posted: Sun Apr 08, 2012 10:19 am
Martians maybe.
It is 100% totally impossible that the dizzy just happened to go from running sweet, to being 180° out.
Post Posted: Sun Apr 08, 2012 11:09 am
paul, no matter how many owners and how thrashed it gets, its still going to be better than your SPOA sloppy suspension bowl of soup unregistered dodgey rust holes dodgeier rust fixing bucket of puss :peaceout:
good work shaune.
Sj70 tintop
Post Posted: Sun Apr 08, 2012 11:13 am
:roll: uh huh Joel.
Post Posted: Sun Apr 08, 2012 11:34 am
haha. got it running, idled fine... put everything else back together, gave it a few revs then it died... no spark this time. there must be a short somewhere, im assuming its what blew the fuse in the first place
can anyone tell me what sort of readings i should get from the wires attached to the coil at all? as in, +12, -12?
Post Posted: Sun Apr 08, 2012 11:42 am
to each of the wires i mean, theres yellow and white attached to + side of coil, and a brown and a brown with a white trace to the -
i also wasnt implying anything earlier with the comment about it being 180 degrees out, i could have easily stuffed something up myself while doing it... joel told me when i bought it the engine was in need of a rebuild, as well as telling me EVERYTHING else that needed to be done. im yet to find something needing repair or replacement that he hasnt already mentioned to me.
Post Posted: Sun Apr 08, 2012 11:49 am
Hahaha. Yeah whincup. Joel knows I <3 him. He will always be my favorite Jew.
Post Posted: Sat Apr 21, 2012 5:40 pm
just following up on this, i discovered the problem... wire that ran to the carby solenoid was damaged and exposed and this was touching the side of the carby. it was only a small portion so only touched while i was driving it. this makes me feel very stupid to have been tricked by such a simple thing haha.
Users browsing this forum: Google [Bot] and 224 guests
