It is currently Thu Sep 17, 2026 5:07 am
Vehicle: 96 Sierra Tintop swb nt coily
Post Posted: Wed Apr 11, 2012 11:39 am
Mate of mine has a sr20 motor and computer i can get for dirt cheap n been thinking bout putting it into my coily but how much work is needed and would i be better off with something else as the 1.3 carby just aint doing it for me at the moment. or can some simple mods.be done to make the 1.3 abit more easy going?
Post Posted: Wed Apr 11, 2012 11:40 am
What problems are you having with the 1.3?
Post Posted: Wed Apr 11, 2012 12:04 pm
Atm its mainly just performance issues. im aware only being a 1.3 its not gonna be the faatest thing out there but it juat seems sluggish. Im still yet to put a snorkel on which should help a little but i went for a trip on the weekend and on the highway just just munching on the fuel.
Just doesnt seem right,and quite an aggessive knocking sound when at idle and under load.
Post Posted: Wed Apr 11, 2012 12:08 pm
Sounds like your motor isn't running properly to me.
Not a lot wrong with the 1.3.
Post Posted: Wed Apr 11, 2012 12:13 pm
you'll have way more dramas trying to make an SR20 work in the sierra (let alone reliability and parts availability) - if you want more power and dont mind spending some money, get yourself a 1.6L EFI engine (G16). its pretty much a bolt-in modification.
Vehicle: 1995 Suzuki Vitara JX LWB G16B
Post Posted: Wed Apr 11, 2012 1:00 pm
My 1.3 was shit, then i got a new carby, then i rebuilt the engine, each time it got doubly better, the i actually tuned the thing and it got even better still, new coil new leads new plugs, just as much power increase, took off the egr installed a cat converter and new rear muffler onto the existing extractors, lights up the 27" BFG's on tarmac pulls alright, you still know it's small but now it's a happy revvy little thing,
not saying you wanna go to all that effort, but i found out that the little 1.3L isn't a slug after all they're mostly just old and thrashed and need some TLC, my only plans in the future is a carby rebuild and if i wanna get crazy a port n polish and cam,
a friend of mine has a 1.6 head on his and it screams,
the potential in the 1.3 is often overlooked,
i suppose it's what your into, i enjoyed getting more out of the engine i already had than taking the easy way out
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Wed Apr 11, 2012 1:56 pm
I don't think most people would say fitting a g16B or an sr20 was "the easy way out"
In fact, you've touched on the main reason the g13 is troublesome - the carby.
The other reason the g13 is a hassle to work with is there's no useable, obvious auto gearbox option. Both of these problems don't arise with either a g16b or SR swap.
Having seen an SR swap into a Sierra, I'd avoid one myself. Too many fiitment issues.
Post Posted: Wed Apr 11, 2012 5:17 pm
hold off on the snorkel if you are thinking of a swap i run mine on the passenger side with the 1.6 :)
saves paying for two
Post Posted: Wed Apr 11, 2012 5:41 pm
buy transfer gears, WAY cheaper than an engine swap of any kind.
Post Posted: Wed Apr 11, 2012 6:05 pm
This is why i love forums...
Theres not one person who knows a thing or two theres squillions...
Think i might give the 1.3 an overhaul,probably well over due.
Thanks for all the quick responses guys
Post Posted: Wed Apr 11, 2012 6:06 pm
Oh and wheres the cheapest place to get transfer gears?
Post Posted: Wed Apr 11, 2012 6:27 pm
you can't beat lowrangeoffroad for transfer gears http://www.lowrangeoffroad.com/
Post Posted: Wed Apr 11, 2012 8:18 pm
Being a zook newbie,what gears and parts do i need to get?
Post Posted: Wed Apr 11, 2012 8:24 pm
you cant just go buy gears.... you need to match the gears to the tyre size you're running. And if the info under your name is correct you've got a coily, which means you have to change to a leafy tcase before you can even consider putting gears in.
unless you're running larger than 235/75r15 you wont NEEEEED gearing, but it would help a fair bit.
Post Posted: Wed Apr 11, 2012 8:25 pm
4.16 gearing will sort 235's out.
Post Posted: Wed Apr 11, 2012 8:39 pm
Ive gotta set of 31's ready to go so if gears will be needed may aswell do it in one go. and why will i need to chanfe yo a leaf transfer case?
Vehicle: '94 suzuki maruti
Post Posted: Thu Apr 12, 2012 8:04 am
coily transfer is chain driven, leafy is gear driven. the gears you purchase replace some of the gears in the case, therefore wont fit a coily.
Post Posted: Thu Apr 12, 2012 9:54 pm
Ohhhhhhh well i see now.
Mmk gonna have to ponder abit on this one now.
Anybody know where i can get a descent but cheap carby kit?
Post Posted: Thu Apr 12, 2012 9:58 pm
repco
Post Posted: Thu Jul 12, 2012 4:56 pm
how did you go?
all running good now?
did you fit your 31's
and did you end up getting a leafy transfer with gears?
 Profile YIM
Vehicle: 1985 Holden Drover
Post Posted: Thu Jul 12, 2012 5:03 pm
I just want to get peoples opinions again on this :lol:
1989 WT Sierra.
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Jul 13, 2012 7:12 am
Iv got a 8valve g13b with the the hollow crank (came out of a 92 holden barina -auto) rebuilt pretty stock with extractors and mildly shaved head and no bullshit will rev to 8000 rpm I was shocked as I did have the timing at -10 btdc I still have trouble believing it and I own it.. it was just rebuilt properly a bloke at staford built it for like $1500 maybe I just got lucky I don't know
Green? greeeen is nice !
Users browsing this forum: No registered users and 174 guests
