If your trying to fit manual freewheeling hubs to a Jimny then the best and cheapest way is to source some Sierra hubs then get a set of benT adapter rings from benT in the business section on this forum.
I then just remove the vacuum lines of the front diff then blocked of the lines coming from the car to stop the 4wd light from flashing.
Users browsing this forum: No registered users and 338 guests
