It is currently Tue Aug 04, 2026 6:30 pm
Vehicle: 89 vitara swb aka. sherman
Post Posted: Fri Apr 20, 2012 8:31 am
I have a vitara 89 swb. its been rolled( by me. whoops) it runs fine drives sorta alright but is very capable.
first question... idler arm bush is shagged. can i get a new bush or is it a whole new jo andb?
Second... its never going to see the road again, its a bush beast. throw some ideas at me. its been lifted 2in. bullbar winch perspex screenand high ehaust out let and snorkel. what else can i do to her?
Post Posted: Fri Apr 20, 2012 8:36 am
Chuck a 2" body lift in, chop the guards a little, throw on some 31's or 32, with hilux Cv's in the front and go cane the arse out of it!
dunno about the idler arm.... but as for what you can do to it, check the "Rigs of AZ" thread - theres a few serious vits in there.
That said though, what terrain does it do most often? No point building a rock crawling weapon if it only sees dirt tracks like in your pic... if it does only see dirt tracks i'd be more inclined to build it for some rally style driving =) lol
Post Posted: Fri Apr 20, 2012 11:03 am
the idler arm bush is available separately from suzuki, or you can pick a complete non-genuine idler arms off ebay usually, then there is the heavy duty idler arm from Sky Manufacturing http://www.lowrangeoffroad.com/index.ph ... r-arm.html
personally i'd cut the shit out of the guards & fit 31" muddies
Post Posted: Sat Apr 21, 2012 7:12 am
Im goin for all round monster. water rocks sand bush everything. has been lifted running 31 muddies. how hard is it to fit hilux cvs? Mine are near shot. My plan is to build a beast of a car, that nothing stops, on a budget of 2000. ive spent 1200 already including buying it.
Post Posted: Sat Apr 21, 2012 9:36 am
I run the heavy duty idler arm from Sky Manufacturing,
I highly recommend it if fitting larger treads,
as the stocker can bend.
Its self lubricating, too, steers very nicely.
Changing bush alone can be a bugger of a job, anyway
Post Posted: Sat Apr 21, 2012 10:02 am
You will probably want some lower low range gearing before anything else if you want an all out weapon. Capability is no fun when it's hard to control due to shitty high gearing
Post Posted: Sat Apr 21, 2012 10:09 am
all out weapon, but reliable... i'd go:
Gearing, 31" muds on offset rims, air lockers front and rear, tougher CVs and axles (are they available for vitara?)
Post Posted: Sat Apr 21, 2012 11:40 am
Its a bush hack and he's only got $800 left in his budget :wink: weld the rear, lockright the front and Lux cv's.
Made in JP. Built in WA.
Post Posted: Wed Apr 25, 2012 7:34 am
Lsd rear diff is doin its job. fronts me big let down. Lockright? Is that a spool locker? Im gonna go for the new idler arm. Luxxy cvs seem to be the shit apparently, so thats a given. are they bolt straight on or 50 hours of work and three cases of beer?
Now you guys seem to be right into ya zooks, and rightly so, so im guessin you know what recovery gear to have and teqniqes. ive got two blocks, snatch strap, lil one tonne winch and about 30 meters of cable extention. i gust run the winch through the blocks and get 4-5 meters of 4 tonne pull. seems to w ork. unless shes right down. then it gets fun.
Post Posted: Wed Apr 25, 2012 7:56 am
lsd? i doubt it, locking the front you are gonna have pieces of diff housing everywhere if you arent careful (prob will sooner or later even if you are)
Post Posted: Wed Apr 25, 2012 8:08 am
If its only a bush car cut the shit out of it
Any thing that dont make it move get rid of it
The lighter the car the less shit will brake
Weld the rear
Tc gears
Auto locker front
Rubber under the front pinion and a metal strap over it
This should help with the front diff lifting up and snapping in half
Get a steel diff and cromo axles when u get some more money
Front cv shouldn't be to bad .just make sure u adjust ur steering stops out . To much steering lock is the main killer of cv
Strut mount flip and v6 gv front coils
Ball joint spacer and gemi coils rear with commodoor shocks
Post Posted: Wed Apr 25, 2012 7:42 pm
33s no gearing welded rear has eaten thru 4 rear axles so far the front is still going strong
F#%ING [P] PLATER
 Profile YIM
Post Posted: Sat May 12, 2012 8:24 am
Thanks guys. this i my plan as of now. leavin rear end alone. cant cut much more out of it . gonna auto lock the front cut the guards, sliders to save breakin it n half, better cvs fof when i finish destroying this set. the engine needs love.... badly.... but after that. an eboost kit to give me grunt!!! So what do we reckon?
Post Posted: Sat May 12, 2012 12:25 pm
What better CVs?
Otherwise sounds alright. Front diff hasn't exploded yet?
Post Posted: Sun May 13, 2012 8:29 am
See what i can get aftermarket. front diff seems fine but im waiting for issues to arise. gotta auto lock it though. The motor is my main worry. shes gettin sad... blows clouds of smoke and hard to start. rebuild i think. no major knocks or rattles in the donk just think me rings are shagged.
Post Posted: Sun May 13, 2012 4:46 pm
There's F-all aftermarket CV options that I'm aware of. About the easiest thing is the stub axle then Hilux conversion - there's a few of us that have either done it or are working towards it. Otherwise the best upgrade is a spare one (or two) in the boot.
Motor sounds a bit sad, but hopefully as you say not catastrophic.
Users browsing this forum: Google [Bot] and 324 guests
