It is currently Fri Nov 13, 2026 4:43 pm
Post Posted: Fri Apr 20, 2012 3:33 pm
9I've just blown up my original 1.3 in my coily.
ive got another 1.3 in a leafy but its a bit tired with 210,000 on the clock so i dont want too go to the trouble of putting it in then finding ill have to replace it further down the track
i want too do a 1.6 conversion but if finding it very hard to find a decent one. would it be worth it putting it a full reco 1.6 from suzistore like this? (http://www.suzistore.com.au/shopexd.asp?id=1611)
i need some i dears, please help :|
cheers james
' Just smile and wave boys ... smile and wave '
Post Posted: Fri Apr 20, 2012 4:32 pm
The 1.6 need to be from the same month and year as yours or newer due to emmissions laws.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Apr 20, 2012 4:54 pm
My sierra had 450,000 on the clock..
Swapping the motor in a sierra only takes about 2 hours (or less depending on your skills), and will keep you running till you find a good used 1.6.
imho You should go efi or not bother when you do, so you will need most of the motor and the loom and ecu and the conversion kit.
Post Posted: Fri Apr 20, 2012 7:00 pm
When I move bring both zooks around and we chuck the engine in
Sj80,31 claws, lift, winch, 6.5
Users browsing this forum: Google [Bot] and 74 guests
