| Author |
Message |
holdenrules
Joined: Sun Jul 27, 2008 11:30 pm Posts: 181 Location: Rockhampton
Vehicle: 84 Lwb Ute
 Posted: Sat Apr 21, 2012 7:25 am |
Hey all I got a 84 lwb Sierra and my horn won't work. Any onee know where the relay is for them as I can't seem to find it. Replaced the horn for a new one so has to be wiring. Any help would be great. Cheers
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Sat Apr 21, 2012 7:34 am |
Does the horn have a fuse? There's only 6 fuses in a 1 liter? I'd try there.
holdenrules
Vehicle: 84 Lwb Ute
 Posted: Sat Apr 21, 2012 8:21 am |
Checked all fuses and yes there's only 6 in the 1 liters but none are for the horn.
sogone
 Posted: Sat Apr 21, 2012 9:12 am |
Stupid question. Have you got the ignition turned on? My horns in the 1 liters won't work unless ignition is on.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat Apr 21, 2012 11:21 am |
There is no relay for the horn. It has constant power to the horn and is activated by earthing at the steering wheel. Check you have power at the horn. Check you have continuity to earth.
The problem is most likely the contact at the back of the steering wheel.
royce
 Posted: Sat Apr 21, 2012 11:25 am |
or the steering shaft uni, or rag joint, dont think 1 litres had the earth bypass wire on them like later ones
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Sat Apr 21, 2012 11:27 am |
Mine used to come and go. It was weird. Must of been the contacts. It was better when it wasnt working. Offroad, hit a bump, bip! Hi!
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sat Apr 21, 2012 11:33 am |
My mate with the army green hilux's horn does that haha.
_________________ mlm
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Sat Apr 21, 2012 5:26 pm |
i added a relay for my horn in my old sierra. used the original 2 horn wires as the relay trigger. upgraded to a horn i pulled from something from the wreckers, think it might have been an old falcon.,and wasnt sure if standard wires could handle it.
first things first, use a multimeter to check that its getting power first... im in gracemere and im free tomorrow, happy to lend a hand if needed.
