It is currently Sat Aug 01, 2026 5:23 pm
Vehicle: 82 1ltr, 93 1.3 with 6.5's
Post Posted: Sat Apr 21, 2012 9:03 am
Heya
I have a 82 1l zook that im going to put a g13a in with a 5 speed box
Just wondering if there are any obstacles or interferences with fitting it in and are there any mods that need to be done
Post Posted: Sat Apr 21, 2012 9:31 am
Gearbox tunnel needs widening a bit with a hammer,
unless you have a body lift.
Is better to run a 1.3 radiator,
as the 1.0 sits too low, and cooling system can get vapour lock at top.
Causing carby choke issues and overheating, sometimes.
Bonnet clearance is an issue, easily solved with body lift,
1.3 bonnet or modding 1.0 bonnet with a power bulge/scoop.
Tailshaft bolt patterns are different, but theres plenty of solutions for that.
Best to use a 1.3 jackshaft, as the 1.0 is a bit longer.
The rest is just fabricating gearbox and motor mounts, as they are not the same.
Post Posted: Sat Apr 21, 2012 12:04 pm
Ohh bugger. so quite a bit of work needs to be done
How much body lift is required
Post Posted: Sat Apr 21, 2012 12:10 pm
A 2" body lift is all that most people use.
Vehicle: '94 suzuki maruti
Post Posted: Sat Apr 21, 2012 5:30 pm
correct me if im wrong but i thought NT bolt pattern is the same as the 1L. so if the 1.3 is from a NT sierra it shouldnt be an issue.
Post Posted: Sat Apr 21, 2012 6:00 pm
1L is different.
Post Posted: Sat Apr 21, 2012 9:01 pm
1L is different.
X2. NT and 1.0 use the same bolt size but the pattern is smaller on the 1.0. WT/Vitara is a bigger pattern and bolts.
Post Posted: Sun Apr 22, 2012 12:10 am
there ya go. i knew WT was different, but thought 1L and NT gear was same pattern. i'll just shut up...
Post Posted: Sun Apr 22, 2012 12:46 am
Atta boy :wink:
Sorry. had a bottle of OP rum tonight. Little tipsy now. :roll:
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 348 guests
