It is currently Sun Oct 11, 2026 5:27 pm
Post Posted: Sun Oct 19, 2008 5:52 pm
Has anyone seen one of these before? It's used to pick up the presence of exhaust gas in the cooling system. I have seen them used at rad shops. I gotta take my zook in to get tested, but was wondering what they are worth to buy.
Vehicle: MY2019 Jimny
Post Posted: Sun Oct 19, 2008 7:51 pm
Is it used for checking head gasket integrity?
Post Posted: Sun Oct 19, 2008 8:09 pm
Yep.
Post Posted: Mon Oct 20, 2008 2:11 pm
I have used em, they will only work if you have CO in the coolant, not a myriad of other things
Post Posted: Mon Oct 20, 2008 3:18 pm
The only place that can come from is exhaust isn't it?
Post Posted: Mon Oct 20, 2008 3:31 pm
no its from combustion gasses into teh cooling system (IE break or crack from the cylinder to there NOT exhaust port or anything) they wont get a crack to exhaust or oil passage or atmosphere though
so they are a good test to do but nothe the only test to do
BTW, I have seen them test negative with a crack to the cooling system and seen them test positive with nothing wrong, fresh clean water seems to help
unless you are using fluid or its running rough or overheating all the time now I would be inclined to just leave it and see
Post Posted: Mon Oct 20, 2008 3:38 pm
Yeah, combustion gasses is what I meant.
Cooling system pressure test too?
It is overheating all the time now. Level seems to be OK, and it runs alright though.
Post Posted: Mon Oct 20, 2008 4:21 pm
pressure test is good if you are losing coolant and cant find it
get your rad checked and replace the thermostat, sometimes if they get really hot they fail and dump crap from the block into the radiator
Vehicle: '92 Sierra
Post Posted: Mon Oct 20, 2008 6:42 pm
Did you consider your that maybe your timings out or maybe running lean? Did you ever fix that airflow meter? What makes you think it is the rad? Seems funny for it to all of a sudden pack it in unless its the thermostat as already mentioned.
Vehicle: '92 Sierra
Post Posted: Mon Oct 20, 2008 6:43 pm
Probably a another stupid question but is the fan working properly?
Users browsing this forum: No registered users and 170 guests
