| Coolant sniffer http://auszookers.com/forum/viewtopic.php?f=5&t=3199 |
| Author: | Damo [ Sun Oct 19, 2008 5:52 pm ] |
| Post subject: | Coolant sniffer |
Has anyone seen one of these before? It's used to pick up the presence of exhaust gas in the cooling system. I have seen them used at rad shops. I gotta take my zook in to get tested, but was wondering what they are worth to buy. |
| Author: | lump_a_charcoal [ Sun Oct 19, 2008 7:51 pm ] |
| Post subject: | Re: Coolant sniffer |
Is it used for checking head gasket integrity? |
| Author: | Damo [ Sun Oct 19, 2008 8:09 pm ] |
lump_a_charcoal wrote: Is it used for checking head gasket integrity?
Yep. |
| Author: | royce [ Mon Oct 20, 2008 2:11 pm ] |
I have used em, they will only work if you have CO in the coolant, not a myriad of other things |
| Author: | Damo [ Mon Oct 20, 2008 3:18 pm ] |
royce wrote: I have used em, they will only work if you have CO in the coolant, not a myriad of other things
The only place that can come from is exhaust isn't it? |
| Author: | royce [ Mon Oct 20, 2008 3:31 pm ] |
no its from combustion gasses into teh cooling system (IE break or crack from the cylinder to there NOT exhaust port or anything) they wont get a crack to exhaust or oil passage or atmosphere though so they are a good test to do but nothe the only test to do BTW, I have seen them test negative with a crack to the cooling system and seen them test positive with nothing wrong, fresh clean water seems to help unless you are using fluid or its running rough or overheating all the time now I would be inclined to just leave it and see |
| Author: | Damo [ Mon Oct 20, 2008 3:38 pm ] |
royce wrote: no its from combustion gasses into teh cooling system (IE break or crack from the cylinder to there NOT exhaust port or anything) they wont get a crack to exhaust or oil passage or atmosphere though Yeah, combustion gasses is what I meant. royce wrote: so they are a good test to do but nothe the only test to do Cooling system pressure test too? royce wrote: unless you are using fluid or its running rough or overheating all the time now I would be inclined to just leave it and see
It is overheating all the time now. Level seems to be OK, and it runs alright though. |
| Author: | royce [ Mon Oct 20, 2008 4:21 pm ] |
pressure test is good if you are losing coolant and cant find it get your rad checked and replace the thermostat, sometimes if they get really hot they fail and dump crap from the block into the radiator |
| Author: | Hybrid [ Mon Oct 20, 2008 6:42 pm ] |
Did you consider your that maybe your timings out or maybe running lean? Did you ever fix that airflow meter? What makes you think it is the rad? Seems funny for it to all of a sudden pack it in unless its the thermostat as already mentioned. |
| Author: | Hybrid [ Mon Oct 20, 2008 6:43 pm ] |
Probably a another stupid question but is the fan working properly? |
