http://auszookers.com/forum/
Transfer stuck in neutral.
http://auszookers.com/forum/viewtopic.php?f=5&t=32003
Author:  sideways [ Sat Apr 21, 2012 11:58 pm ]
Post subject:  Transfer stuck in neutral.
Yeah, yeah, I know, shifter bush.
Given this is a 1981 SJ40 with a non-switch case, will the bush from a switched case fit?
Could it be anything else? At the time I was fixing a transfer mount and pulling the front tail shaft out, from underneath I changed it from low 4 to neutral so I could turn the shaft then I got distractracted and went off to do something else. When I came back I found it was stuck in neutral. You can move the stick in a 20mm square and that's it. Force or rocking or forwards/reverse input from the gear box wont move it.
I have not yet tried to pull the stick out and change gears with a screwdriver ect.
Bloody car, I had a trip planned for today. :roll:
Thanks
Hayden
Author:  want33s [ Sun Apr 22, 2012 9:56 am ]
Post subject:  Re: Transfer stuck in neutral.
Try lifting the stick a bit before trying to shift.
Author:  sideways [ Sun Apr 22, 2012 1:59 pm ]
Tried that, nothing. :/
I've tried just about everything in terms of stick positioning.
Will the bush from a switched case fit a non switch case?
Also, I need the boot that goes on the case, will a switched one fit?
Author:  want33s [ Sun Apr 22, 2012 4:08 pm ]
The rubber boot is same same but I'm not sure about the shifter sheet.
