It is currently Mon Aug 03, 2026 11:26 pm
Post Posted: Sun Apr 22, 2012 11:12 am
i have a few short sides here and a long side with a broken cv.... how do i get one off one onto the other?
apparentky ya just hit em off.... but i cant get it too work! :roll:
back in a built sierra!
Post Posted: Sun Apr 22, 2012 11:19 am
There are a couple of ways to do it..
Be prepared though as it will prob be a waste of time...
Most times when you remove the CV it damages the end of the axle where the CV clip locks on and cannot be reused.
This is how I do it but with a vise instead of tube.
http://www.youtube.com/watch?v=S0_jL83jMH8
Make sure you tape up the seal seat on the axle so you don't damage it.
Vehicle: 2018 DMAX
Post Posted: Sun Apr 22, 2012 2:56 pm
I've found every time I have removed a broken CV from a good looking shaft, that the spline has been damaged when the cv let go. But worth a shot anyway, I use the trick posted above and it works most times.
Post Posted: Sun Apr 22, 2012 6:05 pm
cheers boys!
got the short side off easy as...had hack the brokin one off with a grinder!!!!!
the spline is fine...this broke really weird....broke the spline off in the hub and took the hub with it!....
Post Posted: Sun Apr 22, 2012 6:18 pm
Would hilux CV's handle that method better?
Post Posted: Mon Apr 23, 2012 7:47 am
Hilux's don't usually break the end of the shaft, they just snap the lock ring like happened in the video above.
Users browsing this forum: Google [Bot] and 290 guests
