It is currently Wed Aug 05, 2026 1:52 pm
Vehicle: '78 lj80
Post Posted: Mon Apr 23, 2012 9:33 am
Hi all,
Just wanting to shed some light on if the AW4 that is used in the Vitaras is the same as the AW4 in jeeps?
Reason I ask is im looking at ordering an Atlas, as I know they make atlas to bolt up to an AW4, will it bolt up to my AW4 in my Vitara?
Thanks heaps!
8)
ThisIsYourLife&ItsEnding1MinuteAtATime.
Post Posted: Mon Apr 23, 2012 9:36 am
they are the same gearbox that is used in Jeeps, pajeros, and a million different other cars. but not sure if the casing is different or not which would effect if it will bolt up
Post Posted: Mon Apr 23, 2012 9:41 am
Or the output shaft length and spline.
Vehicle: '78 lj80
Post Posted: Mon Apr 23, 2012 9:54 am
What spline count are the vit aw4s?
Post Posted: Mon Apr 23, 2012 10:12 am
the gearbox spine that outputs to the transfer? not sure of the size but its the same size as the sierra gearbox output.
Vehicle: LJ50V, SJ70
Post Posted: Mon Apr 23, 2012 11:31 am
From Wikipedia:
"Transmissions used in later AMC vehicles came with either a 21-spline or a 23-spline output shaft. Transmissions coupled to four-cylinder engines normally used 21-spline output shafts. The 23-spline manual transmission was universal in the Eagle lines and was generally used with six-cylinder applications. All transfer cases were available with inputs matching either 21- or 23-spline shafts, so transmission swaps are possible among various models and years.
The Aisin-Warner four-speed automatic transmission (AW4) was co-designed by AMC and Borg Warner then built by Aisin in their new facility for use in then all new Cherokee XJ's new inline six-cylinder 4.0 L design. It was manufactured by Aisin-Warner, a member of the Toyota group, in partnership with Borg-Warner. It shares many parts with the Aisin 450-43LE that is used in Toyota off-road vehicles.
The AW4 is also used behind the 2.5 L (150 in³) AMC Straight-4 engine. It has a removable bell housing with a mount for the crankshaft position sensor. Early AW4s used 21-spline output shafts. In 1991 the AW4 was changed to a 23-spline output shaft, concurrent with adoption of the High Output (commonly known as H.O.) inline six-cylinder engine. Some sources state that the output shaft spline change occurred for the 1990 model year. The change most likely occurred during the 1990 model run with early 1990 models receiving 21-spline transmission and later models receiving 23-spline. If swapping transmissions in 1990 model year vehicles either swap the transfer case as well or make sure to check spline count. The input on the transfer case can also be changed to match the output shaft spline count. Rear-wheel-drive-only transmissions all have the same spline count on the output shaft, only 4x4 models are affected by differing spline count.
Gear Ratios for the AW4:
1st: 2.80
2nd: 1.53
3rd: 1.00
4th: 0.75 (23-spline, 0.705 21-spline)
Models that used the AW4:
1987–2001 Jeep Cherokee (XJ) 4.0 L
1993–1993.5 Jeep Grand Cherokee (ZJ) 4.0 L
1987–1993 Jeep Comanche 2.5 L
1987–1992 Jeep Comanche 4.0 L "
So it seems the Jeep AW4 Autos were available in either spline size depending on the engine size. You would just need to specify a 21 spline Atlas. HOWEVER, The rear case adapter and output shaft will not be the same length as the Vit. The mounting bolt pattern will also be in SAE dimensions, not metric. See pic below.
This is the same spline sizes used with the AISIN manual gearboxes. The Jeep AX5 is a 21 spline box which is the same spline size and design as a Toyota G52 box and is the same as the case used in a GV2.5lt (See THIS THREAD). The Jeep AX15 is a 23 spline case and the same as a Toyota R150/R154. In both of these Jeep transmissions, the rear of the case is quite different to the comparable Suzi/Toyota cases, in order to mate to the specific Jeep Transfer Cases.
Post Posted: Mon Apr 23, 2012 11:55 am
For more close pics of a Jeep AW4 tranny, have a look at This Page. It also gives some neat info for anyone who might be thinking of putting a Vit AW4 into a maunal Sierra.
Post Posted: Mon Apr 23, 2012 12:04 pm
As the AW4 is virtually the same as a Toyota A340 Auto used in 4Runners, you could also do a similar swap to the Manual one I showed above for a shorter overall length, but the down side of this is the Toyo Auto is only made for Chain-driven transfercases with limited (ie: NIL) aftermarket reduction gear choices. You will need to get an adaptor from Inchworm to fit Toyo gear-driven cases, or even DUAL transfers!
Vehicle: '78 lj80
Post Posted: Mon Apr 23, 2012 12:09 pm
Not sure if I understood this correctly?
Am I unable to do it because of the rear case adapter and output shaft will be different?
Could I maybe source the parts off a jeep aw4? Or will that be a no go since it'll be in SAE?
Thanks heaps for your help!
The other option is I could run the atlas divorced..?
I have the kit to make the vitara 4speed divorcable already..?
Vehicle: '78 lj80
Post Posted: Mon Apr 23, 2012 12:13 pm
I have two hilux gear driven hilux cases here, I was planning on going duals, but by the time you add up the cost to build them strong and properly, in my opinion you may as well add the extra coin (which isn't all that much) and buy an atlas, that will be alot stronger then a lux case will ever be?
Thanks heaps for all your help 303zuke! Highly appreciated!
Post Posted: Mon Apr 23, 2012 3:01 pm
Ethann wrote:
I have two hilux gear driven hilux cases here, I was planning on going duals, but by the time you add up the cost to build them strong and properly, in my opinion you may as well add the extra coin (which isn't all that much)and buy an atlas, that will be alot stronger then a lux case will ever be?
This is what I would do if I had my buggy build over again.
Vehicle: '78 lj80
Post Posted: Tue Apr 24, 2012 5:10 am
I'm hearing ya!
Users browsing this forum: No registered users and 267 guests
