It is currently Tue Nov 03, 2026 10:32 am
Vehicle: 2000 model Suzuki Jimny
Post Posted: Sun Apr 15, 2012 7:57 pm
Hi there,
I just got back from spending an awesome weekend at Stocktane beach in the bog stock Jimny. But it has shown a problem.
When i was working the car hard through the soft sand and big dunes it was fine, but when i pulled over and was idling the car would cut out and not start up. I would have to wait about 10-15 minutes before it would start. The temperature gauge was only at about half way so i am a bit confused as to what was going on. It did this about 5 times over the weekend.
It also did it once on a trip up to the Watagans where i pulled into a servo to fill up after being on the freeway at about 100 kmph for about 2 hours and it just didn't start for 10 minutes.
Any help would be much appreciated.
Thanks,
Post Posted: Sun Apr 15, 2012 10:15 pm
There was a thread about this a while ago...
Apparently Jimny's have a fuel accumulator thingo setup that can fail.
Sorry I don't know much more than that.
Vehicle: Suzuki Jimny
Post Posted: Sun Apr 15, 2012 10:25 pm
What motor do u have. At work we replace the cam position sensor and it fixes problems like your when customers mention the symptoms likes your problem
Post Posted: Mon Apr 16, 2012 8:04 am
Thanks for that,
I have been reading alot of things that mention the cam sensor as a source of problems so will have a look into it.
Thanks,
Vehicle: 2003 Jimny Auto
Post Posted: Mon Apr 16, 2012 5:04 pm
My cam pos sensor needed replacing. Worked for me when i had same symptoms
Post Posted: Wed Apr 18, 2012 12:18 pm
depends on engine, could be the crank pos sensor if an M13A
and that "fuel accumilator thingo" i believe was my problem last year you are referring to. different symptoms, and that was just a loss of fuel pressure due to a o-ring getting dislodged on the fuel pump assy.
but i changed the crank sensor as part of my fault finding.
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Apr 18, 2012 5:34 pm
Hi there,
I have the G13BB engine in my Jimny if that is able to narrow down the possible sources. I believe that my model Jimny doesn't have an external cam positioning sensor.
Any help is much appreciated.
Thanks,
Post Posted: Wed Apr 18, 2012 7:36 pm
JuniorJoel wrote:
Hi there,
Thanks,
Sure does - It's at the back of the cylinder head. They regularly give trouble.
Post Posted: Wed Apr 18, 2012 9:33 pm
Oh!, from what i had read this model Jimny didn't have one. I will have a look at it tomorrow.
Thanks,
Post Posted: Wed Apr 18, 2012 9:43 pm
Sorry, Just realized that the G13BB only has a Cam positing sensor and not a Crank Position sensor.
Thanks,
Vehicle: 84 Suzuki Sierra
Post Posted: Sat May 05, 2012 7:42 pm
Did this fix the problem? I am having similar trouble with my jimny.
Post Posted: Sat May 05, 2012 8:44 pm
Tank fuel breathing system is a possibility.
Try running with tank cap off, to check if it is an issue.
Post Posted: Sat May 05, 2012 9:08 pm
Sorry for not replying. I haven't actually done anything to the engine yet as the problem has not occurred anytime since i went 4X4 driving.
However I am planing to go soon so if it does play up again i will probably change the Cam positioning sensor just to rule one thing out.
Thanks,
Users browsing this forum: Google [Bot] and 120 guests
