It is currently Wed Aug 05, 2026 1:02 pm
Post Posted: Wed Apr 25, 2012 5:05 pm
A hair brained scheme ( as we seem to have) we would like some dimentions of the swivel balls from a solid axle rocky?
any one????
Post Posted: Wed Apr 25, 2012 5:32 pm
any one????
If no one pipes up, I might be able to get some off a Scat for you in a few weeks.
What dimensions do you want and what are you planning?? :D
Post Posted: Wed Apr 25, 2012 6:16 pm
Main dimension is the internal diameter of the stub axle (ie what size shaft you can jam through one). Other dimensions may be required (the internal diameter of the ball on the end of the axle, and its depth), but the stub is the most critical I guess.
Planning nothing, your know nothing! :D
Clearance Hole Technology :P
Post Posted: Wed Apr 25, 2012 6:27 pm
also an asia rocksta diff :)
Post Posted: Thu Apr 26, 2012 12:00 am
Sorry but I wont be much use to you then, not unless you tell me what you're doing!!
:P :P
Na, I wouldn't be able to pull it apart, it's not my car you see.
Well, not unless I can convince them to sell it to me (ohhhhhhhhh I want a Scat so very much!! :D :D I have no use for it though). :twisted:
The guy who owns it also owns those LJs I was talking about on FB. :)
Post Posted: Thu May 03, 2012 4:06 pm
diahatsu F73/78 had 6 bolt hubs, you can buy avm replacments for them
aparently the hub assemblies are compatable with the older models too
Users browsing this forum: No registered users and 203 guests
