It is currently Tue Nov 03, 2026 1:50 pm
Vehicle: SJ51T
Post Posted: Thu May 03, 2012 9:26 pm
So sometimes it is pretty hard to go from 4wd to 2wd in my stock standard transfer case.
Next week I am putting 6:4 gears in it and while it is all to bits is there a piece i could organise now to swap out.
if you guys can think of anything that might be an obvious cause for this difficulty in changed from 4 to 2 and visa versa.
Chur
Humble beginnings
Vehicle: 1985 Holden Drover
Post Posted: Thu May 03, 2012 9:28 pm
Is this while your still or moving?
1989 WT Sierra.
Post Posted: Thu May 03, 2012 9:36 pm
Tcase bush might be buggered
Post Posted: Thu May 03, 2012 10:41 pm
Could be axle wind up.
Or actually tail shafts wind up.
Caused by differences in speeds front to rear on harder surfaces
reverse a little
forward a little,
usually unjams it.
But can be as said in posts above
Post Posted: Thu May 03, 2012 10:43 pm
This is a common issue
Post Posted: Thu May 03, 2012 11:06 pm
reverse a little
forward a little,
usually unjams it.
Haha had to do that quite a bit. Seems to be very picky at times :lol:
1989 WT Sierra.
Vehicle: SJ51T
Post Posted: Sat May 05, 2012 5:17 pm
excuse my n00bness but you don't have to pull the t-case apart to change the bush ?
Humble beginnings
Post Posted: Sat May 05, 2012 5:26 pm
No it can be done from inside the cabin, thru the tranny stick hole.
Can't remember exact details.
Easier after body lift.
Vehicle: SJ51T
Post Posted: Sun May 06, 2012 10:39 am
Mathew and I are putting the body lift in my Sierra on Thursday anyways :)
Thats if Widetread get my rims delivered tomorrow like they should have had done on Friday >_<
Humble beginnings
Post Posted: Sun May 06, 2012 2:36 pm
If you go from under neath and undo your switch then you and undo the thin that holds the stick in had to take mine on the side of a track should take about 15 mins to change it
Users browsing this forum: No registered users and 442 guests
