It is currently Thu Nov 05, 2026 10:30 am
Post Posted: Fri May 04, 2012 10:06 am
Guys, the flexi line under the master cylinder, bout 120mm or so, can anyone tell me the end fittings please, I want to get about 30mm longer ones made up, but do not want to undo them as this will mean no brakes or a useless bit of work to get them working again, if I cannot get them done locally.
Bottom is installed first, 14mm, top must have a barrel union of sorts, 19mm.
Post Posted: Fri May 04, 2012 10:18 am
theres a few companies like Enzed and hosemaster etc that can come out and make the lines for you on site.... might be worth looking into something like that? Then you know its 100% correct at least (although i doubt theyre cheap to get to come out).
Post Posted: Fri May 04, 2012 10:23 am
Im out at coffins, just had a bloke out here, 2 hours travel, 1 either way, at $70 per hour, I would take the lines in, but if they have no ends, means no car, or I have to bleed the stupid things, by myself.
Post Posted: Fri May 04, 2012 10:31 am
could you take photos of the ends with a ruler next to them, measure it up and email to them to have made up? Surely they'd have a big book of hose fittings to know what manufacturers use what etc???
Users browsing this forum: Google [Bot] and 45 guests
