It is currently Thu Oct 08, 2026 10:00 pm
Post Posted: Mon Oct 27, 2008 9:22 pm
i just installed a 2' body lift and the car seems to jump out of second gear occassionally. before the body lift second gear use to vibrate alot through the gear stick but now actually jumps out of gear. this mainly happens when turning which i find odd. any ideas wat it could be? i havent checked yet but maybe the gearstick hits the tunnel when in 2nd gear and gets pushed out??
Post Posted: Mon Oct 27, 2008 9:43 pm
mine hit against the tunnel, i rekon if you take off the boot, the shifter will be hitting against the tunnel, i neede to hack at it a bit with the grinder to get it to clear
85 NT, SPOA, 2" BL, sliders, f&r lockers, bull bar
Vehicle: LJ20 LJ50
Post Posted: Mon Oct 27, 2008 10:23 pm
octupus strap will keep it in 2nd ;-)
Camels have nice toes
Vehicle: MY2019 Jimny
Post Posted: Mon Oct 27, 2008 10:25 pm
x2
Post Posted: Tue Oct 28, 2008 12:07 am
wats an octupus strap? looks like ill be pulling it apart and checking it out. what would the vibration be from maybe slector fork or missing tooth??
Post Posted: Tue Oct 28, 2008 12:10 am
an octupus strap is a bungee strap
Post Posted: Tue Oct 28, 2008 12:11 am
I used tin snips to trim mine :D
Post Posted: Tue Oct 28, 2008 12:17 am
yea ill see if it hits..... maybe it might be possible to bend the shifter to clear the floor??
Post Posted: Tue Oct 28, 2008 12:56 am
Yeah thats another option. I believe mart did that in his zook?
you would have to pull the stick out though. He also used a press to bend it.
I only had to notch out about 20x20mm of the hole
Post Posted: Tue Oct 28, 2008 8:06 pm
If you've got one of those big rubber flexy boots (standard), you'll probably find that if you replace it with a thinner leather boot, it will be fine. I got a couple of really nice Saas ones from supercheap, but they are around $30 a boot. Check you low range as well. You will probably find it won't go in 4wd low. For this I just ground out a section of the floor pan and boot bracket with a die grinder.
Post Posted: Wed Oct 29, 2008 2:35 pm
it goes into low range but havent had it off road to see if it jumps out. ill be taking the boots off today and seeing how close it comes
thanks for your help again guys
Users browsing this forum: Google [Bot] and 157 guests
