It is currently Thu Oct 08, 2026 8:55 pm
Vehicle: MY2019 Jimny
Post Posted: Mon Oct 27, 2008 7:12 pm
Hey all,
Today I noticed that my 5 speed is leaking rather badly from the rear, and possible front too.
Is is possible to replace these seals with the box in situ, or does it require removal?
Also, does anyone have a spare for sale?
It is from a 92 sierra.
Post Posted: Mon Oct 27, 2008 10:17 pm
rear can be done in car. for the front it would have to come out.
Post Posted: Mon Oct 27, 2008 10:54 pm
if the front is the gearbox youll need to pull the box apart too, more than likely its the rear main on the engine
or your breather could be blocked too
Post Posted: Mon Oct 27, 2008 11:32 pm
What does a rebuild usually cost?
Post Posted: Mon Oct 27, 2008 11:34 pm
piece of string, I think a parts kit it about $400 assuming all your hard parts inside are OK
Post Posted: Mon Oct 27, 2008 11:39 pm
Makes a second hand one with 6 month warranty look pretty good...
Post Posted: Tue Oct 28, 2008 12:17 am
if you have 1.5 leaks it makes an hours work and $5 for a seal seem pretty good
Post Posted: Tue Oct 28, 2008 12:41 am
Are they easy to replace? I have only ever done a gearbox on my old sunny wagon, it was a PITA (mainly my fault however).
Post Posted: Tue Oct 28, 2008 12:49 am
the rear seal is no harder than a wheel bearing seal, take the jack shaft out and lever the old seal out and refit the new one
replacing the whole gearbox is fiddly cause the hol is barely big enough but would be similar to doing a sunny box
Users browsing this forum: No registered users and 204 guests
