| Gearbox leaks http://auszookers.com/forum/viewtopic.php?f=5&t=3250 |
| Author: | lump_a_charcoal [ Mon Oct 27, 2008 7:12 pm ] |
| Post subject: | Gearbox leaks |
Hey all, Today I noticed that my 5 speed is leaking rather badly from the rear, and possible front too. Is is possible to replace these seals with the box in situ, or does it require removal? Also, does anyone have a spare for sale? It is from a 92 sierra. |
| Author: | mrw82 [ Mon Oct 27, 2008 10:17 pm ] |
| Post subject: | Re: Gearbox leaks |
rear can be done in car. for the front it would have to come out. |
| Author: | royce [ Mon Oct 27, 2008 10:54 pm ] |
if the front is the gearbox youll need to pull the box apart too, more than likely its the rear main on the engine or your breather could be blocked too |
| Author: | lump_a_charcoal [ Mon Oct 27, 2008 11:32 pm ] |
What does a rebuild usually cost? |
| Author: | royce [ Mon Oct 27, 2008 11:34 pm ] |
piece of string, I think a parts kit it about $400 assuming all your hard parts inside are OK |
| Author: | lump_a_charcoal [ Mon Oct 27, 2008 11:39 pm ] |
Makes a second hand one with 6 month warranty look pretty good... |
| Author: | royce [ Tue Oct 28, 2008 12:17 am ] |
if you have 1.5 leaks it makes an hours work and $5 for a seal seem pretty good |
| Author: | lump_a_charcoal [ Tue Oct 28, 2008 12:41 am ] |
Are they easy to replace? I have only ever done a gearbox on my old sunny wagon, it was a PITA (mainly my fault however). |
| Author: | royce [ Tue Oct 28, 2008 12:49 am ] |
the rear seal is no harder than a wheel bearing seal, take the jack shaft out and lever the old seal out and refit the new one replacing the whole gearbox is fiddly cause the hol is barely big enough but would be similar to doing a sunny box |
