| Author |
Message |
mcwilly
Joined: Sun Sep 21, 2008 11:30 pm Posts: 867 Location: nsw, newcastle
 Posted: Mon Oct 27, 2008 9:22 pm |
i just installed a 2' body lift and the car seems to jump out of second gear occassionally. before the body lift second gear use to vibrate alot through the gear stick but now actually jumps out of gear. this mainly happens when turning which i find odd. any ideas wat it could be? i havent checked yet but maybe the gearstick hits the tunnel when in 2nd gear and gets pushed out??
_________________ 1996 sierra + 2" body lift + SPOA conversion + ome
keechox
Joined: Sat Dec 29, 2007 10:30 pm Posts: 242 Location: launceston Tasmania
 Posted: Mon Oct 27, 2008 9:43 pm |
mine hit against the tunnel, i rekon if you take off the boot, the shifter will be hitting against the tunnel, i neede to hack at it a bit with the grinder to get it to clear
_________________ 85 NT, SPOA, 2" BL, sliders, f&r lockers, bull bar
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Mon Oct 27, 2008 10:23 pm |
octupus strap will keep it in 2nd
_________________ Camels have nice toes
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Mon Oct 27, 2008 10:25 pm |
keechox wrote: mine hit against the tunnel, i rekon if you take off the boot, the shifter will be hitting against the tunnel, i neede to hack at it a bit with the grinder to get it to clear
x2
mcwilly
 Posted: Tue Oct 28, 2008 12:07 am |
wats an octupus strap? looks like ill be pulling it apart and checking it out. what would the vibration be from maybe slector fork or missing tooth??
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Tue Oct 28, 2008 12:10 am |
an octupus strap is a bungee strap
Taff
Joined: Sun Aug 13, 2006 11:30 pm Posts: 889 Location: Brisbane
 Posted: Tue Oct 28, 2008 12:11 am |
I used tin snips to trim mine
mcwilly
 Posted: Tue Oct 28, 2008 12:17 am |
yea ill see if it hits..... maybe it might be possible to bend the shifter to clear the floor??
Taff
 Posted: Tue Oct 28, 2008 12:56 am |
Yeah thats another option. I believe mart did that in his zook?
you would have to pull the stick out though. He also used a press to bend it.
I only had to notch out about 20x20mm of the hole
Rockhopper
Joined: Sun Jun 22, 2008 11:30 pm Posts: 1265 Location: Chipping Norton
 Posted: Tue Oct 28, 2008 8:06 pm |
If you've got one of those big rubber flexy boots (standard), you'll probably find that if you replace it with a thinner leather boot, it will be fine. I got a couple of really nice Saas ones from supercheap, but they are around $30 a boot. Check you low range as well. You will probably find it won't go in 4wd low. For this I just ground out a section of the floor pan and boot bracket with a die grinder.
_________________ We're riding in the Ninky Nonk!
mcwilly
 Posted: Wed Oct 29, 2008 2:35 pm |
it goes into low range but havent had it off road to see if it jumps out. ill be taking the boots off today and seeing how close it comes
thanks for your help again guys
