It is currently Sun Aug 02, 2026 2:27 am
Vehicle: Red LWB suzuki vitara
Post Posted: Fri May 11, 2012 2:37 pm
I have a LWB suzuki vitara, I have some slightly bigger than standard tyres they are rubbing in the back guard and pulling the lip out. Just wondering what type of lift to do ???
Post Posted: Fri May 11, 2012 3:50 pm
2 inch body lift from just cruisin on here.
Or suspenion lift, there are a lot of options
I love lamp
Post Posted: Fri May 11, 2012 3:54 pm
bigger hammer
Post Posted: Fri May 11, 2012 4:28 pm
Body lift will help, spring lift won't. Hammer on the seam to flatten it out for now
Post Posted: Fri May 11, 2012 6:27 pm
a spring lift would help, just not as much as a body lift
spring lift raises the chassis higher from the wheels
where as body lift raises the body from the chassis
for more clearance during compression travel go body lift
if you hitting on a chassis piece like where your body attaches go a spring lift
if all else fails go the BFH it never fails
Post Posted: Fri May 11, 2012 6:38 pm
Dunno about you but I compress my suspension when wheeling.
Post Posted: Fri May 11, 2012 6:43 pm
Pretty sure it was clear in the OP that the tyre was hitting the guard.
Cutting, bumpstop spacing or body lift are the answer. Spring lift will only "help" at the mall. Flex the suspension and spring lift makes no difference to tyre/guard clarence.*
Steve
*Unless you have calmini or RD 80mm springs :D
Post Posted: Sat May 12, 2012 4:59 am
what sized tyre are you running on what rim. i ran a king spring lift which is about 40mm and long commo shocks and my 235 on stock rims fit in the back of my lwb vit with out scrubbing and now with a 3" lift they only just rub the body just above the chassis which is flat and doesnt chew the tyre. now with 7" rims with a neg 13 offset no srub at all. so when every body says the spring lift wont help it helped mine.
Users browsing this forum: No registered users and 331 guests
