| Author |
Message |
Trypt
Vehicle: 1.3 Tin Top
 Posted: Fri May 11, 2012 10:00 pm |
Looking into buying a winch. Some advice on what load rating would be great. fleabay have 4000lb with synthetic rope for under $150 worth the risk or should I be looking at something more powerful
ZookFan
Joined: Mon Feb 14, 2011 6:19 am Posts: 3978 Location: Brisbane,samford,QLD
 Posted: Fri May 11, 2012 10:13 pm |
A stock zook is around a tonne.. so factor in a steep hillcimb or deep mud.. and that is a lot of extra power needed to pull the zook.. so min 6000 pound I reckon...
mark_b
Joined: Sat Apr 07, 2012 1:13 pm Posts: 45 Location: mid north coast
Vehicle: 84 suzuki sierra jx S/T
 Posted: Fri May 11, 2012 10:34 pm |
id try and get a 9500lb one. all im doing to my zook is WARN 9500lb winch, snatch strap and tree trunk protector plus the other bits and bobs to be on the safe side. D shackles and stuff. least you will no your gear can get you out of it. you get what you pay for with winches but bud.. try and get a decent brand name one if you can get the coin. backed with decent warranty in case something does play up. just my 2 bobs buddy hope it helps..
ZookFan
 Posted: Fri May 11, 2012 10:38 pm |
Have been told that the zook's chassis does not like huge forces on it..so 8000 pound max I reckon.. I mean 9500 pound is over kill...don't forget you can do a double line pull on any winch so more pulling power straight away...a bit slower tho..
suzukikid
Joined: Sun Jan 14, 2007 10:30 pm Posts: 2803 Location: Melton Victoria!
 Posted: Sat May 12, 2012 7:10 am |
my mate has tat lil winch on his!haha has worked twice on heavy pulls but isnt sounding good at all!
i have 6500p on mine and that is plenty!(have only used it once for my self!) it saved me from goin over end over end..... has pulled other zooks up hills no worry!
_________________ back in a built sierra!
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat May 12, 2012 8:50 am |
I have a 9500lb unit on my Zook and would not fit anything smaller.
ZookFan
 Posted: Sat May 12, 2012 10:12 am |
suzukikid wrote: my mate has tat lil winch on his!haha has worked twice on heavy pulls but isnt sounding good at all!
i have 6500p on mine and that is plenty!(have only used it once for my self!) it saved me from goin over end over end..... has pulled other zooks up hills no worry! Bingo!
mnemonix
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1409 Location: Newcastle NSW
Vehicle: '96 LWB trayback
 Posted: Sat May 12, 2012 10:14 am |
I ran a warn 6000 lb on mine for years and it did the job, but often required a winch block to get enough power. These days I run a 10000 2 speed. The cheaper brands can be more than adequate. Do you drive places away from civilisation where the winch is your only means of rescue?
_________________ Twin charged twin cam twin locked webwheeler
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Sat May 12, 2012 10:18 am |
i had a 12000 on mine as it was almost the same price and im glad it was that big some times. You will end up using it to recover your mates more than your self.
_________________ B4T
Trypt
 Posted: Sat May 12, 2012 5:52 pm |
I dont stray very far from civilization. there is plenty of very nasty, very challenging, very fun tracks on my door step. Im on a pretty tight budget being a student and if i do have to spend extra money to get a more suitable product i will. i would just rather save that money for other things i will use alot more often like good lighting etc.
ZookFan
 Posted: Sat May 12, 2012 11:39 pm |
Get a hand winch if you want to save some money..still good to have in the 4wd..can be used to right a rolled 4wd ect
sherman zook
Vehicle: 89 vitara swb aka. sherman
 Posted: Sun May 13, 2012 8:54 am |
Dont laugh at me but ive gotta teeny lil 2000 pound atv winch on mine that cost me 130 its all a matter of pulleys. through two blocks ive pulled my girl outta deep sand, mud, off rocks, when ive exceeded ramp over angle, and out of one or two predicaments. the down side is, the more blocks you run, less pull lengh you have. I use extention cables to get my anchors lined uout, the i put the block on my first anchor cable, another on front recovery point then out to my second anchor cable. viola! 5mtns of 4 toe pull!pays to have a jack and shovel with you and a set of sand boards.
ZookFan
 Posted: Sun May 13, 2012 12:40 pm |
I will laugh
Trypt
 Posted: Sun May 13, 2012 2:15 pm |
I think i might give it a crack. 4000 with a snatch halves to winch load so, equiv 8000. and there nice nd small so i dont have modify bar to fit it.
