It is currently Tue Aug 04, 2026 3:50 am
Post Posted: Sat May 12, 2012 10:17 am
I just installed 4.9's and all new bearings into a tcase i bought.
Don't know what i did wrong but its making a 'tick, tick, tick' noise?
It does have oil lol
The noise only happens on acceleration, just coasting / going down gears no noise.
Sounds like its coming from the front of the car, if i put tcase into Neutral and 5th gear and accelerate no noise.
Here is a movie of it.
My Maruti build, Click WWW
Vehicle: Daisy
Post Posted: Sat May 12, 2012 11:06 am
It sounds like the jackshaft or a tailshaft is rubbing on something or vice versa. It's only doing it under acceleration because of the load twisting the transfer mounts e.t.c. just enough to make it touch.
Does it do it on overrun or just acceleration, it doesn't sound like a gears problem otherwise it would be there the whole time.
Check for loose wires and cable ties and spots that may be rubbed e.t.c. I know the way mine is setup (transfer boot flipped) I had to pull the boot up high out of the way of the shaft, horrible horrible noise that made!
Post Posted: Sat May 12, 2012 11:30 am
Thanks for that, I just pulled case back out, do you think it might be the input flang as its got a mark where it's been touching ?
Post Posted: Sat May 12, 2012 11:39 am
Got an Smartarse mates that tied a cable tie around a shaft? Haha
Post Posted: Sat May 12, 2012 11:44 am
Hahaha that's a good idea for someone!
Post Posted: Sat May 12, 2012 1:34 pm
yeah it was just the seal guard on the flange, had me worried !
I actually have low range now !!
Vehicle: 4wd
Post Posted: Sat May 12, 2012 3:06 pm
Did you end up using the chipped gear?
Watch out or you'll get sued.
Post Posted: Sat May 12, 2012 3:09 pm
Yeah i did, i asked a few diff places and they said if the chip is smaller then a match head it will be fine so ill see how it goes.
Vehicle: Daisy
Post Posted: Sat May 12, 2012 11:24 pm
Hah, good to see I was on the money for once!
You can just tap the dust covers back onto the flange with a hammer, take it easy though.
Users browsing this forum: No registered users and 249 guests
