It is currently Fri Oct 09, 2026 3:51 am
lesspostingmorewheeling
Post Posted: Wed Oct 29, 2008 12:26 am
what size allen key socket thing is needed to undo the plugs in the diffs,transfer and gearbox?
Post Posted: Wed Oct 29, 2008 12:32 am
there are allen key ones 8O
think its 10mm, grab a 6mm bolt with a 10mm head and see if it fits :)
Post Posted: Wed Oct 29, 2008 12:38 am
Is it allen key?
mine had the squre for the shifter in it! So you wack the shifter in and undo it! 8)
back in a built sierra!
3/8 drive normally fits, use your rachet
Post Posted: Wed Oct 29, 2008 12:42 am
hehe I am pretty sure there are 3 types
square drive, they are 10mm as well but a 3/8 ratceht gets you out of trouble if they arent tight
the pipe plug, these have the square bit that sticks out, these are best to get undone but no good in the drain holes in the diffs :)
and allen key, so proper 6 sided hole, I think these are the best as long as they dont get burred and you have a proper inhex socket
Vehicle: MY2019 Jimny
Post Posted: Wed Oct 29, 2008 12:57 am
Am I correct in thinking that the magnetised Gbox plugs also fit the Tcase and diffs?
What size thread are they?
Post Posted: Fri Oct 31, 2008 12:24 am
3/8 drive breaker bar worked for me, except in the case of the fill plug on the rear diff, where a hammer and chisel did the job.:s
Post Posted: Fri Oct 31, 2008 12:29 am
is there an actual tool that can be bought to undo the square ones?
Post Posted: Fri Oct 31, 2008 12:31 am
3/8th drive I use... works fine.
Vehicle: 98 coily..Max.
Post Posted: Fri Oct 31, 2008 12:33 am
x2
Suzuki...four wheel jive!
98 coily...Camping rig.
Post Posted: Fri Oct 31, 2008 12:40 am
yes there is, but they are often short so you cant swing off em to get em loose anyway
I dont know of anything like something you can stick on a breaker bar but it seems like a good enough reason to waste some time looking at it tomorrow
Post Posted: Fri Oct 31, 2008 12:44 am
The torque wrench I bought is reversible and about twenty inches long..
Guy said I could use it for diff and gearbox plugs.(3/8 drive)
You guys reckon it would be ok or would that put it out of calibration?
Post Posted: Fri Oct 31, 2008 12:49 am
I reckon the less you use em the better
and they arent 3/8" they are 10mm, youll all appreciate the difference when you get a tight one :wink:
Post Posted: Fri Oct 31, 2008 12:54 am
Thank you sir :wink:
Vehicle: 75 Cruiser
Post Posted: Fri Oct 31, 2008 10:24 am
my old 85 sierra required a 22mm (i think) socket for the transfer case and gearbox plugs. not sure if that was factory, but they were all the same so it looked standard.
Post Posted: Fri Oct 31, 2008 10:33 am
You are still talking about diff plugs and gearbox plugs, aren't you??? :twisted:
Post Posted: Fri Oct 31, 2008 1:40 pm
On my 95' sierra both diff filler plugs actually took a 11mm square drive tool, the 3/8 inch drive was too small and chewed out and damage the plugs. i managed to mangle mine but get them off but had to buy new ones from Suzuki to replace them, the new ones measured 11mm as well using vernier calipers.
i hunted around for a 11mm square drive tool but the only place i could find one was part of a kinchrome set which was $80 and that had 6 or 7 other drain plug tools i would never use, so i couldnt justify buying them, i used a 3/8 inch drive and didnt do the plugs up super tight.
All the gearbox and transfer plugs as well as the gearbox fill plugs are all probably 10mm but a 3/8 inch drive ratchet converts to roughly 9.5mm and fits fine.
Post Posted: Fri Oct 31, 2008 2:01 pm
You've got a one track mind........a dirt track :lol:
Post Posted: Fri Oct 31, 2008 7:02 pm
Buy a cheapo 1/2" drive breaker from supercrap and grind it down until its a nice tight fit.
or weld a nut to it :D
Post Posted: Sun Nov 02, 2008 3:35 am
my drover is the same i'm pretty sure i used an 11/16 or something socket on mine
Users browsing this forum: Google [Bot], UBZ and 265 guests
