It is currently Fri Oct 09, 2026 6:10 am
Vehicle: 30s front locker barwork
Post Posted: Mon Nov 03, 2008 12:00 am
hey everyone
i hav a problem i hav no reverse lights n it is not the fuse box n there is no power to the reverse lights at all the brake lights n everything else works i jst fitted a extra reverse light straight to the reverse wires any help would be a appreciated
Post Posted: Mon Nov 03, 2008 12:03 am
Did you fit a relay for the extra reverse light. I bet you didn't and it's overloaded the system :D Otherwise it's an earthing problem
Post Posted: Mon Nov 03, 2008 12:19 am
find the plug on the firewall that goes to teh reverse switch in the gearbox (thin its a red and yellow pair of wires)
unplug it and bridge the wires together on the car side and see if they turn on, if not see if you get power to one of the wires
Post Posted: Mon Nov 03, 2008 12:52 am
wat do u mean by bridgein the wire n i thought i only need a relay if i hav a switch n stuff if i fit a relay will it go back to normal
Post Posted: Mon Nov 03, 2008 12:58 am
go back and describe what you did a bit better, did you fit another light and now it doesnt work or it didnt work before and you tried to fit another light thinking it would work?
Vehicle: MY2019 Jimny
Post Posted: Mon Nov 03, 2008 1:31 am
A relay is there to switch a high current device, which your small wiring cannot handle for long. It is used irrespective of whether a switch is used.
Post Posted: Mon Nov 03, 2008 1:46 am
I have this same problem..I have no actual reverse lights, however i have hooked up some driving lights.
They worked for a while..Now not working..
Suggestions? Find a relay box on firewall?
Going to have to find it :?
Post Posted: Mon Nov 03, 2008 1:49 am
1st step is too see if the switch in the box works and there is power getting to it
Post Posted: Mon Nov 03, 2008 1:57 am
How did you hook up the spot lights? Adding extra lights needs a relay fitted too.
As Royce said, check for power at the switch on the box. Then make sure you have a good earth, in the socket that holds the bulb as well as the wires to the chassis. Check fuses too.
Post Posted: Mon Nov 03, 2008 2:52 am
yeah hahaha i just wired it straight in :twisted:
Sori i hijacked :oops:
May investigate tomorrow.Earth is good, absolut no power to rear reverse light :P
Vehicle: '92 Sierra
Post Posted: Mon Nov 03, 2008 3:33 am
Get some marshmellows ready!
Post Posted: Mon Nov 03, 2008 3:39 am
Have lolly bananas? :lol:
Well i've had no reverse lights for bout 6mths now... :?
Post Posted: Mon Nov 03, 2008 1:08 pm
You've probably burnt out the switch
Post Posted: Mon Nov 03, 2008 1:19 pm
Renamed to BlueJeepy, awaiting fire.
Post Posted: Mon Nov 03, 2008 4:36 pm
Bluejeepy hahahahah....no. 8O
Post Posted: Mon Nov 03, 2008 10:57 pm
before i put the light on i had reverse lights then i hooked up the extra light which is jst a work light straight to the power on the standed reverse light n earthed so if i hav over loaded it how would i fix it
Post Posted: Mon Nov 03, 2008 11:04 pm
Find what is burnt out and replace it. Chances are it is the relay that is rooted.
Post Posted: Mon Nov 03, 2008 11:16 pm
i jst brigded the wires like royce said to n the lights work so wat does that mean is my switch on the gearbox stuffed
Post Posted: Mon Nov 03, 2008 11:17 pm
Maybe...
Post Posted: Mon Nov 03, 2008 11:21 pm
yep the switch is stuffed
Users browsing this forum: No registered users and 127 guests
