It is currently Fri Oct 09, 2026 6:10 am
Post Posted: Sun Nov 02, 2008 11:01 am
Has anyone ever repacked one of these?
Mine seems a little loose, and i'm tossing up whether to stick with it or go to an electric fan.
Post Posted: Sun Nov 02, 2008 11:05 am
can they be pulled apart? you can buy the silicone for them from toyota
electric fans suck :)
Post Posted: Sun Nov 02, 2008 12:49 pm
Yeah they can be as far as i know, would have to have a good look at it.
What's wrong with leccy fans? I wouldn't mind just sticking with the viscous hub fan, but orking on it would be a lt easier with a leccy fan.
Post Posted: Sun Nov 02, 2008 1:03 pm
Let me know if you go electric Damo, I'll take the viscous hub off your hands 8)
Post Posted: Sun Nov 02, 2008 11:11 pm
I reckon suzukis are the wrong shape to get enough airflow through without an engine fan helping it and electric fans never pull enough air through
Post Posted: Mon Nov 03, 2008 3:07 am
Leccy fan is just another system to go wrong. They dont seem to like water and mud for some reason. Simple mechanical is the way to go.
Dan
Post Posted: Tue Nov 04, 2008 1:24 am
I wanna ditch mine for a thermo..
Think about this..
Sure.. you may have a fan that constantly cools your engine but go for a swim and she will spray the water all over the engine bay and snap blades (worse case).
I would also think you would get a little more engine response from not having to drive the fan off the belt..
So I think a Thermo with a switch would be a good thing ??
Post Posted: Tue Nov 04, 2008 2:09 am
whats better, cool engine and not always being worried about the temp or some water splashed in the engine bay?
you do get some more power but its not worth it
Post Posted: Tue Nov 04, 2008 5:37 am
Think about this..
Thats why I loosen me fan belt when going for a deep swim. Spraying water over the engine bay, no problems, zuk is fairly well water resistant.
Post Posted: Tue Nov 04, 2008 10:39 pm
dual thermos!
well thats what i plan to run anyway. shoule be ok. i may have to look into a water tight system around the connections.
Web wheeler extroadinaire
Users browsing this forum: No registered users and 132 guests
