It is currently Tue Oct 06, 2026 12:04 am
Post Posted: Tue Nov 04, 2008 11:19 pm
hey guys had a new carby put on last week old one was buggered however it now seems to use more fuel only getting 200-250 a tank :(
anyhoo i looked at the carby i dont know what im looking at but i can see two outlets that to me appear as though a hose should be connected each pic shows the outlets any help fellas
outlet 1 smack bang in the middle of the pic
Outlet 2 gold outlet in between 2 black hoses
Post Posted: Tue Nov 04, 2008 11:28 pm
yeah they should thats for the auto choke, it could be staying on and would explain the fuel usage a bit
cant remember exactly where they go but one is on the metal pipe out the rear of the water pump and the other the manifold, might pay to get somebody here with a sierra to check
Post Posted: Tue Nov 04, 2008 11:36 pm
thanks royce aka god
im not to up to date with cars but im confident outlets will not be there for no reason
anyone with a zook can you have alook for me and let me know where theses go
Post Posted: Wed Nov 05, 2008 1:07 am
Looking at my manual they appear to be the water inlet and outlet for the carby , this would explain why you are using too much fuel as the carby might not get to the right temp and make the choke turn off , your hoses might have been joined up to bypass the carby for some reason , Cheers Paul.
Post Posted: Wed Nov 05, 2008 1:13 am
Cheers Paul.
Post Posted: Wed Nov 05, 2008 1:19 am
hey another point of interest royce is that when i first start my car it idles around 900rpm
within minutes of warming up it goes to 1500rpm
it remains there all the the time sounds like choke is still on hey so my car never idles below 1500
Post Posted: Wed Nov 05, 2008 1:26 am
thanks paul
Post Posted: Wed Nov 05, 2008 11:10 am
When you say you had a new carby put on, I hope you did'nt pay a mechanic to do it, cause I'd be slapping him upside his head. Apart from the missing water hoses, could be anything causing your other problems, such as incorrectly fitted vacuum hoses, vacuum leaks, or incorrectly set carby. As Royce mentioned, the best thing to do is get someone with a Sierra out so you can compare hoses, adjust your fast idle screw, idle up screw and your idle screw. Mixture screw should be sealed from the factory, but if somebody had previously removed the seal, adjust your mixtures too.
Post Posted: Thu Nov 06, 2008 4:06 pm
so angry
so angry
i pointed out the missing hoses they said oh they were not there before BULLSHIT
ALL THEY DID was turn idle down so yeah when driving it idles at 900rpm instead of 1500 but now on first start it struggles to idle at 200rpm and stalls
PLUS i just used half a tank and only got 70kms out of it
so over it think im taking her somewhere else
Post Posted: Thu Nov 06, 2008 8:01 pm
Alright boys problem solved
Post Posted: Thu Nov 06, 2008 9:08 pm
And you did ? , Cheers Paul.
Post Posted: Thu Nov 06, 2008 9:52 pm
ok ok ok
well the two outlets you guys where correct and it had been bypassed
however there was no flow into the carby to allow for the temp to be detected and to allow for the choke to disengage
so i fixed the hoses into there correct places and adjusted idle and its perfect
choke now disengages once it has warmed up
choke being constantly on explains using 17l for 82 kms hahahaaha
but thanks for the help especially the diagram
Vehicle: 98 coily..Max.
Post Posted: Thu Nov 06, 2008 11:07 pm
I love happy endings :woohoo: :goodjob:
Suzuki...four wheel jive!
98 coily...Camping rig.
Post Posted: Fri Nov 07, 2008 12:15 am
When I rebuilt my motor the last time I forgot to put the water in the radiator , so the throttle body had no flow and it ran like a bag of shit , It would not idle and would not rev , adding water , straight away back to idle and still runs fine until today.
Also you need to check the flow when you flush your radiator as corrosion will cause the pipes to block causing poor performance , Cheers Paul.
Post Posted: Sun Nov 09, 2008 11:49 pm
ok an update on my economywhen i started noticing issue with carby my
first tank was 240km
then i got a new carby on it and still had issues major over fueling
second tank 140km
then i found the missing water inlet hoses to the carby for the choke etc fixed that up
third tank 360km and thats not running out will fill up tomorrow to found out how many litres and the economy id say its back down to 10l/100 easy
SO HAPPY
Post Posted: Mon Nov 10, 2008 12:21 am
youll be wanting to change your oil, all that fuel has to end up somewhere
Post Posted: Mon Nov 10, 2008 12:47 am
yeah getting a service and a wheel alignment this week :)
Users browsing this forum: Google [Bot] and 157 guests
