http://auszookers.com/forum/
Sierra Lean seems worse on my zuk than anyone elses
http://auszookers.com/forum/viewtopic.php?f=5&t=3348
Author:  dj_konix [ Fri Nov 14, 2008 11:21 pm ]
Post subject:  Sierra Lean seems worse on my zuk than anyone elses
Hey There,
I have a calmini lift kit in my zuki with reverse shackles and the lean on my sierra is atrocious..like as in left corners need to be taken super slow as to know tip it over :(
i have spare calmini leaf packs from when i bought it..maybe try swapping one of them over? or maybe swap the leaf packs from the other side over?
I havent had a sierra before let alone a 4wd, and to me looking at the leaf pack it looks twisted...i will take some pics for you guys but i need to sort this problem ASAP because its irritating to not be able to take off camber hills or anything that will cause the drivers side to tip..
Author:  steve [ Fri Nov 14, 2008 11:28 pm ]
Post subject:  Re: Sierra Lean seems worse on my zuk than anyone elses
Does the Calmini kit have left and right springs? The King Spring kit i got years ago had left and right springs, so you had to make sure you got them in the right place because they were set different to each other.
pics would be good :)
Author:  Damo [ Fri Nov 14, 2008 11:33 pm ]
Same goes for my Kings springs Steve. Actually the PASSENGER side is 10mm higher.
Cut dow on the beer and dim sims? :lol:
Author:  steve [ Fri Nov 14, 2008 11:36 pm ]
That's what i said peaceout
Author:  Brett [ Fri Nov 14, 2008 11:39 pm ]
unless its a aus brand put your left springs in the right side. most of the market is in the u.s.a and it for a left hand drive.
other wise put a extra leaf in the right, the longer spring the better as it will start to work earlyer in compresson
Author:  Cozook [ Sat Nov 15, 2008 11:32 pm ]
Just pour concrete into side thats higher.....stop when level..:)
Author:  jimbo_jones [ Sun Nov 16, 2008 12:50 am ]
sand bags work 2 :thefinger:
Author:  Cozook [ Sun Nov 16, 2008 11:14 pm ]
Yeah but they fall on ya head when ya roll it...:)
Author:  Mike [ Sun Nov 16, 2008 11:26 pm ]
they don't if you tie them down with octopus straps :lol:
Author:  GRPABT1 [ Wed Dec 03, 2008 10:32 pm ]
I've got the calmini kit too and I also get bad lean, I will swap the front and rear leaves side to side soon, I don't think they come with a left and right specific pack as in america the fat bastard in the drivers seat combats the lean.
