It is currently Wed Nov 04, 2026 10:58 am
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sun Jun 24, 2012 9:02 pm
Needs some help with some figures for my build.
Confirm 93 Vit LWB on standard wheels RPM @ 100 is 3200
RPM @ 60 is .........
Post Posted: Sun Jun 24, 2012 9:19 pm
(3200/100)*60 = 1920RPM in the same gear
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Mon Jun 25, 2012 12:41 pm
Thanks JR
now to work the ratios
Post Posted: Mon Jun 25, 2012 3:12 pm
by my calcs 100 in a vit should be 3300 at 100 in 5th
so with your vitara 1.6 and gearbox. on WT diffs with 3.7 diffs
if you use a 4.9 : 1 transfer your looking at 3298 at 100 in 5th
gearing sorted
Post Posted: Mon Jun 25, 2012 3:13 pm
thats on a 31 inch tyre
on 29s like you were talking about it makes the road revving a bit too high,
even if you drop down to 4.1 transfer gears its still too high, this is where you find issues
Post Posted: Mon Jun 25, 2012 3:41 pm
tanshi wrote:
3298 at 100 in 5th
The 1.6 is much more happier @ ~3600
Lil Foot!
Post Posted: Mon Jun 25, 2012 4:19 pm
i used to run mine at 3400 happily, but for every day driving i wouldnt run it much higher.
Online
Post Posted: Mon Jun 25, 2012 5:19 pm
Mine runs 3700 and seems fine at that. I'm sure it could run lower, but I like the gearing off road with 6.4's and 5.12's and a true 35" tyre.
Post Posted: Mon Jun 25, 2012 6:52 pm
Interested to hear your reasoning on this
Lil Foot!
Post Posted: Mon Jun 25, 2012 7:55 pm
Thanks guys.
I was going through all the ratios last night and could only get 4.16's to keep the range at 100@3200 but if you recon it would be better a bit higher then maybe 4.9's will work.
I've also decided to go 31 for the road and 33 off so if your right Tanshi its time to go shopping for gears and a few other goodies
found this if anybody's interested http://www.grimmjeeper.com/metric_gears.html
Post Posted: Tue Jun 26, 2012 10:02 am
I daily a 1.6 on 30's and go on yearly trips upto Cairns and back. I run 4.9's and 3.7 diffs which brings me to around 3.5-3.6krpm at a true 100. Stock sierra gearing and 30's it was pushing 3100 @ 100 in 5th and it required a lot of throttle input to actually make something happen. You will probs find that the vits were geared that way to try and reduce NVH. Peak torque on the g16 is up around 4000RPM. Peak torque is also where the engine is most efficient which I would consider being a daily that will be used to cruise @ 100-110KPH
Lil Foot!
Post Posted: Tue Jun 26, 2012 12:02 pm
Using the grimmjeeper I got 100k @ 3500
using the lepayne I got 100 k @ 3400
Using .86 (vit gearbox) 1.634 (4.9 transfer gears in hi) 3.7 (WT diffs) and 31 tires
To me these fig are a bit hi but from what your saying would be better anyway
http://www.lepayne.com/gears.html
Post Posted: Wed Jun 27, 2012 9:45 am
U should be aiming at at least 3600 at 110
My vit sits around 3200 and it sucks
Users browsing this forum: Google [Bot] and 128 guests
