Joined: Sun Mar 04, 2012 6:11 pm Posts: 464 Location: Brisbane, Petire
Posted: Wed Jun 27, 2012 9:42 pm
you can get replacements from zanifi.it or something like that. they are very expensive and your better off welding a piece on to the where the stock rubber stopper hits on to. as unless your car is brand new i doubt you will be able to unscrew them.
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
Posted: Thu Jun 28, 2012 6:36 am
Ok. By looking at the zanfi site, I can see that blocks are not a direct fit using factory fit. They use a bolt to drop through from the hole in the top of the tower through the mating surface and into the block. Easy enough to make with a lathe.
_________________ If you can read this, please tip me back over
Users browsing this forum: Google [Bot] and 111 guests
