If you just want a bolt in job you can use rear oem carry springs, you just might need to drill the rear perches and maybe longer shackles.
Otherwise you need to do some more reading, then extend the chasis, move the bump stops, change the shock towers & shockies and extend your brake lines and steering column.
Users browsing this forum: No registered users and 552 guests
