It is currently Thu Oct 08, 2026 4:41 pm
Vehicle: 75 Cruiser
Post Posted: Wed Nov 19, 2008 11:21 pm
these look like a good idea for sierras. No it's not advertising for locktup4x4, coz at $180.00 a pair, no one here will buy them :lol: .. but i like em.
These heavy duty rod ends are ideal for today's flexible suspension systems. Super strong, these joints will hold up to years of punishment. The outer shell is a single forged piece. The inner flex ball is made from 8620 tool steel and rides on high quality polyurethane bushings. Heavy-duty, hardened steel washers hold the joint together. Creeper Joints are super flexible and allow for up to 40 degrees of movement when used with spacers. A threaded grease fitting is provided on top for lubrication. The flex ball is drilled for cross lubrication flow from the shell to the link mount bolt. Each joint includes a jam nut!
Creeper Joints are also available in a shackle mount for use with leaf springs. Using a Creeper Joint on the shackle end of a leaf spring reduces spring binding and increases suspension flex. Creeper Joint shackle mounts are sold in pairs and do not include the shackles, bolts or spring bushings.
Vehicle: WR250F/Jeep XJ
Post Posted: Thu Nov 20, 2008 12:39 am
They'd be fine on rocks but once you start playing in the mud I can imagine that they would get flogged out pretty quickly by dirt and grit entering the ball joint..At 180 a pair you'd hope that the grease nipples would allow you to pump a hell of a lot of grease through and out to keep it running clean.
Cool idea tho for those zook owners wanting super flex. :P
Post Posted: Thu Nov 20, 2008 1:00 am
buy a set Steve and we'll see how they go
Users browsing this forum: No registered users and 170 guests
