| creeper joint shackle mount http://auszookers.com/forum/viewtopic.php?f=5&t=3375 |
| Author: | steve [ Wed Nov 19, 2008 11:21 pm ] |
| Post subject: | creeper joint shackle mount |
these look like a good idea for sierras. No it's not advertising for locktup4x4, coz at $180.00 a pair, no one here will buy them ========================
These heavy duty rod ends are ideal for today's flexible suspension systems. Super strong, these joints will hold up to years of punishment. The outer shell is a single forged piece. The inner flex ball is made from 8620 tool steel and rides on high quality polyurethane bushings. Heavy-duty, hardened steel washers hold the joint together. Creeper Joints are super flexible and allow for up to 40 degrees of movement when used with spacers. A threaded grease fitting is provided on top for lubrication. The flex ball is drilled for cross lubrication flow from the shell to the link mount bolt. Each joint includes a jam nut! Creeper Joints are also available in a shackle mount for use with leaf springs. Using a Creeper Joint on the shackle end of a leaf spring reduces spring binding and increases suspension flex. Creeper Joint shackle mounts are sold in pairs and do not include the shackles, bolts or spring bushings. |
| Author: | dank [ Thu Nov 20, 2008 12:39 am ] |
| Post subject: | Re: creeper joint shackle mount |
They'd be fine on rocks but once you start playing in the mud I can imagine that they would get flogged out pretty quickly by dirt and grit entering the ball joint..At 180 a pair you'd hope that the grease nipples would allow you to pump a hell of a lot of grease through and out to keep it running clean. Cool idea tho for those zook owners wanting super flex. |
| Author: | just_cruizin [ Thu Nov 20, 2008 1:00 am ] |
buy a set Steve and we'll see how they go |
