It is currently Fri Oct 09, 2026 1:38 am
Vehicle: MY2019 Jimny
Post Posted: Fri Nov 21, 2008 10:50 pm
G'day -
I have a 2 point immobiliser to install, was thinking of doing the coil and fuel pump (unless someone has a better idea), but I was after ideas on where to tap into the correct wires...
If I can find where in the loom the fuel pump is powered fed from then I would prefer to choose that point, rather than going right to the fuel pump.
I will try and find a wiring schematic with colour codes, I suppose that will help (even though I am a bit colour blind)...
So, where would be good to tap into the wires?
Thanks, Linc.
Post Posted: Fri Nov 21, 2008 10:56 pm
on a sierra? they have mechanical fuel pumps
tap the ignition feed to everything and the starter motor feed at the ignition switch loom to the right of the speedo (you have to pull it out to get to it)
the only place you can tap an immobiliser into a sierra to prevent them being hotwired is between the dizzy and coil but youll never hide the wiring to prevent a thief that wants_it_that_bad from not seeing it and disabling it
Vehicle: 1999 Jimny
Post Posted: Sat Nov 22, 2008 1:45 pm
couple of wires to a tazer under the seat for when they sit down........
Just don't forget it yourself.
Post Posted: Sat Nov 22, 2008 1:55 pm
Oh yeah... :wink:
You mean the HT wire?
Post Posted: Sat Nov 22, 2008 1:58 pm
no you have a wire from the positive coil terminal to the dizzy that powers the ignition module and 1 from teh dizzy to the coil negative that switches it, you could cut into that one to stop it being hotwired
Post Posted: Sat Nov 22, 2008 2:01 pm
Ah ok... Thanks Royce.
Post Posted: Sat Nov 22, 2008 8:33 pm
And the number 1 immobilisation point to stop you zook getting stolen is...
kneecaps :wink:
Post Posted: Sat Nov 22, 2008 8:54 pm
I take it you install the kneecaps into the offender?
aka
aka
Post Posted: Sat Nov 22, 2008 11:00 pm
I can tell you there will be plenty of DNA evidence if any one tries to pinch your zuk!
Experience is something you dont get until just af
Post Posted: Sun Nov 23, 2008 12:53 am
I reckon a 150dba peizo mounted somewhere inaccessible would serve the purpose well too, but with less shit for me to clean up...
I remember seeing in Sth Africa a dude had a loaded gun mounted under his seat, that went off when someone tried to hotwire it from memory...
Post Posted: Sun Nov 23, 2008 4:42 pm
Well, I got it all installed - Wasn't too difficult, just a bit time consuming looming/taping up all the wires.
I managed to remove the ignition barrel and construct the new loom in the garage, to save me doing it in the footwell all hunched over.
Cheers for the help guys...
Users browsing this forum: No registered users and 146 guests
