It is currently Sat Oct 17, 2026 3:12 pm
Post Posted: Wed Aug 01, 2012 1:52 pm
I have just done a carby g16a conversion on my sierra, the head has been off the motor, everything was put back how it was before I touched it. It will only run on 2 cylinders and backfires, I have swapped leads around but no difference, I took the rocker cover off and verified that the spark is going to the right cylinder at the right time and it is. Any suggestions? :(
Post Posted: Wed Aug 01, 2012 2:35 pm
Timing belt lined up right?
Post Posted: Wed Aug 01, 2012 2:40 pm
timed 180 degrees out
Post Posted: Wed Aug 01, 2012 2:41 pm
It was aligned with the marks, I put it back the same way it came apart but I don't know whether it was right when I pulled it apart.
Post Posted: Wed Aug 01, 2012 2:42 pm
Wouldn't swapping the leads fix that though? It didn't.
Post Posted: Wed Aug 01, 2012 3:02 pm
Turned the dizzy 180 degrees and it wouldn't even run on 2 cylinders.
Users browsing this forum: Google [Bot] and 189 guests
