It is currently Fri Oct 09, 2026 7:27 am
Post Posted: Tue Nov 25, 2008 2:18 am
Hey just wondering if the Coily dash was a straight swap with the wide track? If not how much needs to be done to get it in there?
Post Posted: Tue Nov 25, 2008 3:44 am
No it's not a straight swap. Brackets will be different, and i'm sure wiring will be too. A copy of the coily wiring diagram would help. Good luck, & post pics when you're done!
Post Posted: Tue Nov 25, 2008 4:08 am
Wiring for guages? If so im getting the coily guages with the dash but things like, will it line up with the steering column, will the wide track vents go out the right places? Will it just look shit and out of place? Does the firewall on the widetrack curve different as they dont have a fold down windscreen? Anyone know these sort of things? If i get it in i will post plenty of pics! Wont be getting it for about 1 month for postage reasons
Post Posted: Tue Nov 25, 2008 3:59 pm
Steering column is probably in the same place. I doubt the vents are going to line up perfect, you'll have to do some fiddling for sure, but you might get lucky. It will look good if you can pull it off. They look good in coilys so they should look fine in a WT. You should be right with the firewall, I mean they still fit the same engine in there so there shouldn't be any reason that the firewall is massively different.
Users browsing this forum: No registered users and 231 guests
