| Strut spacers or strut mount flip? http://auszookers.com/forum/viewtopic.php?f=5&t=34030 |
| Author: | Samwich [ Tue Jul 10, 2012 1:39 pm ] |
| Post subject: | Strut spacers or strut mount flip? |
as the title stats What are everyones thoughts????? |
| Author: | larry [ Tue Jul 10, 2012 4:34 pm ] |
| Post subject: | Re: Strut spaces or strut mount flip? |
i started with mount flip, cheap and easy and returns droop to stock with 2inch lift springs now running strut spacers, just as easy, still cheap as and gives a good amount of droop strut mount flip (215 tyres) ![]() strut spacers (30" tyres)
| Author: | Samwich [ Tue Jul 10, 2012 5:05 pm ] |
would you recomend one over the other?? |
| Author: | Fatzook [ Tue Jul 10, 2012 5:20 pm ] |
Strut top flip is almost free. Start there. |
| Author: | atari4x4 [ Tue Jul 10, 2012 5:21 pm ] |
^^^ what he said |
| Author: | Samwich [ Tue Jul 10, 2012 5:39 pm ] |
Alright, Will do |
| Author: | larry [ Sun Jul 15, 2012 10:20 am ] |
Do a strut mount flip and next time you order something on lowrange put some strut spacers in the order theyre like 40$ |
| Author: | Charlie Brown [ Sun Jul 15, 2012 5:07 pm ] |
| Post subject: | Re: Strut spacers or strut mount flip? |
does anyone know if you can get 1" strut spacers from anywhere? or is that about how much extra a strut flip gives? has anyone got a strut mount approved as in engineered approved? love that winch bar larry! thanks boys |
| Author: | christover1 [ Sun Jul 15, 2012 8:00 pm ] |
My strut mount flip gave me about 20mm, bit less than an inch. But its more than that at the wheel. |
| Author: | Charlie Brown [ Fri Jul 20, 2012 9:47 pm ] |
Yeah Im thinking a strut mount flip would be good! Im just wondering if someone could tell me wether these strut spacers ( http://www.bits4vits.co.uk/store/vitara ... od_17.html) need a 19mm spacer or a 1.5" spacer in the front suspension as if the spacer gives double then shouldnt it only need a 19mm spacer? thanks guys! |
| Author: | christover1 [ Fri Jul 20, 2012 9:58 pm ] |
Charlie Brown wrote: Yeah Im thinking a strut mount flip would be good! Im just wondering if someone could tell me wether these strut spacers ( http://www.bits4vits.co.uk/store/vitara ... od_17.html) need a 19mm spacer or a 1.5" spacer in the front suspension as if the spacer gives double then shouldnt it only need a 19mm spacer? thanks guys! A 20mm spring spacer sounds right to me, but Bits4Vits could give a recommendation |
| Author: | Charlie Brown [ Fri Jul 20, 2012 10:24 pm ] |
okey dokey thanks for that mate =) |
