i have a stock leafy transfer case and was wonder when changing the gearing did you replace all the bearings in it or just the ones provided in the kit? if so did it make a big difference, would you suggest it?? and also the output, or input not sure which one it is but they suggest replacing one with a heavier duty one? what are the pros and cons of doing this??
cheers jamie
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
Posted: Wed Nov 26, 2008 12:14 am
if the kit your looking at comes with bearings there should be enough to do the whole case if not you should replace the bearings because the ones in the case would be pretty old and it would be one less thing to worry about down the track
_________________ [quote="Fluffy"] yeah right mate like Im gunna mov
Users browsing this forum: No registered users and 163 guests
