It is currently Tue Oct 27, 2026 7:19 am
Post Posted: Wed Jul 18, 2012 7:02 pm
hey all just wondering what the diff ratio in a sierra is?
i think the vitara is 5.12
cheers
Post Posted: Wed Jul 18, 2012 7:03 pm
3.7:1 & 3.9:1 are the common ratio's
Post Posted: Wed Jul 18, 2012 7:04 pm
3.7 & 3.9 & 4.1 are the common ratio's
:wink:
Post Posted: Wed Jul 18, 2012 7:06 pm
and the vitara is 5.12?
so can i have the vitara diff centre in a sierra diff? if aanyone knows
Post Posted: Wed Jul 18, 2012 7:07 pm
yes, vit front is the same size as sierra front or rear
Post Posted: Wed Jul 18, 2012 7:08 pm
4.6 or 5.12 are most common.
Post Posted: Wed Jul 18, 2012 7:11 pm
Kool thanks for the help guys
Post Posted: Wed Jul 18, 2012 7:16 pm
Is it only the front that is the same and is in only in certain models.
Post Posted: Wed Jul 18, 2012 7:17 pm
All vitara (89-98) front diffs are compatible with sierra.
Post Posted: Wed Jul 18, 2012 7:18 pm
Is it only the front that is the same and is in only in 99% of models.
The front is the same on all models except goofy headlight XL7 and current models.
Post Posted: Fri Jul 20, 2012 10:09 am
GV has a stupid air operated front diff. You might be able to swap the GV ratios into a sierra diff. If so then you could have 4.3, 4.8 and 5.12 ratios.
Oh and theX90 has 4.8 diffs
Post Posted: Fri Jul 20, 2012 7:45 pm
thanks mate. so if i have a 4.8 ratio at the front and a 5.12 at the rear that will wreck the transfer box?
Post Posted: Fri Jul 20, 2012 7:55 pm
Yes it will
Post Posted: Fri Jul 20, 2012 7:59 pm
just run 33's on the front & 31's on the rear 8)
Post Posted: Fri Jul 20, 2012 8:09 pm
LOL, so i can put the vitara front centre in the front sierra housing? are they the same amount of bolts? (sorry just making sure so i dont buy a diff for no reason)
Post Posted: Fri Jul 20, 2012 8:11 pm
you're better off getting the vitara R&P built into the sierra 3rd member as the vitara one is alloy & known to be made of porcelain reinforced glass.
Post Posted: Fri Jul 20, 2012 8:17 pm
cheers atari,yeah the diff centre is alloy as well forgot, would it be eaiser getting the whole front sierra diff with the 4.8 ratio and then changing the rear centre to a sierra or is the 5.12 ratio better?
Post Posted: Fri Jul 20, 2012 8:23 pm
the higher the number the greater the reduction.... you work it out.
vitara rear diffs are larger than sierra... sierra F/R diffs = vitara front diff in size etc.
Post Posted: Fri Jul 20, 2012 8:42 pm
yeah i know how the reducking works but if it makes muck difference
Post Posted: Fri Jul 20, 2012 8:48 pm
yes, it's a step backwards if you fit 4.8's.
EDIT: sierra's don't come with a 4.8:1 ratio so I've got not idea WTF you're on about :?
Post Posted: Fri Jul 20, 2012 8:54 pm
well wtf is it 4.3 or something
Post Posted: Fri Jul 20, 2012 8:56 pm
4.6 i mean
Post Posted: Fri Jul 20, 2012 8:58 pm
read the 3rd post again
Post Posted: Fri Jul 20, 2012 9:01 pm
then whats the 4.6 ratio out of
Post Posted: Fri Jul 20, 2012 9:08 pm
SV420 manuals & a few others
Post Posted: Fri Jul 20, 2012 9:10 pm
oh right, well for no ill stick with the standard vitara centre see how it goes then when i breakes ill get some other centre
cheers
Post Posted: Fri Jul 20, 2012 9:13 pm
If it is a 4.6 ratio Want to swap a 5.12 centre for it
Post Posted: Fri Jul 20, 2012 9:19 pm
yep ill see how i go may have it in for a while but ill let you know if i wanna get rid of it
Users browsing this forum: Google [Bot] and 172 guests
