http://auszookers.com/forum/
Blue smoke
http://auszookers.com/forum/viewtopic.php?f=5&t=34121
Author:  cairns27 [ Fri Jul 13, 2012 7:09 am ]
Post subject:  Blue smoke
I'm blowing blue smoke while going downhill on gears.It used 500mls of oil in 600k's of hard highway driving.
It's the original motor in a '87 serria, done 300,00k's, but has plenty of power, and dosen't blow somke under power.
Can i just fit a relay somewhere to fix this.
Tar
bye
Author:  Chop [ Fri Jul 13, 2012 7:25 am ]
Post subject:  Re: Blue smoke
Yes there is a relay for that, they can be expensive coz its a genuine part.
bye
Author:  oohsam [ Fri Jul 13, 2012 9:46 am ]
Dont underestimate the power of relays!!
LOL!...
Author:  HarryHoudini [ Fri Jul 13, 2012 10:05 am ]
I think that its sucking oil down the valve stems,need a Re-coed Head but with that sort of K's its best to do the whole motor.
Author:  vandle [ Fri Jul 13, 2012 10:48 am ]
Agree, valve stem seals are worn, minimum reco the head but at 300k it would be wise to do a bottom end rebuild as well while you have it apart
mine did that as well going down hill under compression
Author:  BlueSuzy [ Fri Jul 13, 2012 11:10 am ]
Relays will not fix smoke unless its a smoke machine.
Sound like its internal.
bye
Author:  2stroker [ Fri Jul 13, 2012 1:24 pm ]
If it is not blowing smoke under power and it still has plenty of go at 300,000km it is more than likely that engine has been out before and had a freshen up. I wouldnt even pull the head off, I would just do valve stem seals with the head on and see how you go.
Author:  tonyevans [ Fri Jul 13, 2012 3:32 pm ]
^ x 2
Author:  cairns27 [ Fri Jul 13, 2012 7:14 pm ]
Thanks fellas valve stem seals is me.
bye
