It is currently Thu Sep 17, 2026 4:10 pm
Post Posted: Fri Jul 13, 2012 5:51 pm
Power window thing. I have a new master switch on the door side..driver window is up and down ok. Passenger window will go down only. When I put power to the motor wiring direct as in not thro switch. Nothing. Window doesnt go up or down. What am I missing Fuses and thermal thing are all good. Cheers in advance.
Post Posted: Fri Jul 13, 2012 6:43 pm
what vehicle? your profile doesnt say.
but regardless, time to whip out the multimeter, put it at the motor, trigger the switch and see if you get 12vdc (you obviously wont, or itd be working), then do same at switch to make sure you have 12vdc supply at the switch, then trace your way until you find where the power is/isnt, then youve found your break.
or you may have a limit switch somewhere preventing things. dunno
MY BUILD THREAD HERE!!!!!
Post Posted: Fri Jul 13, 2012 7:27 pm
cheers scales its a swb soft top vit..
Vehicle: 1985 Holden Drover
Post Posted: Fri Jul 13, 2012 9:39 pm
Hey guys just a side question. I dunno if the soft top doors are different, but how do you get the trim off a 95 JLX estate?
1989 WT Sierra.
Post Posted: Sat Jul 14, 2012 5:03 am
First - on the direct wiring thing - recheck your connections - if you can wind the window down using the driver's side switch, the motor is probably good, and applying power directly to the window should also make it go down - there will be two wires to the motor, apply power one way it goes down, the other way it goes up - it's possible to have a defective motor, either worn brushes or a defective commutator/winding so it works intermittently, but that will affect both up & down.
Second - check the passenger side switch - the switches are cross wired to prevent a short circuit when one switch is set up & the other set down - both switches need to work in up/off/down positions for the window to work properly - a defective passenger side switch can cause the driver's side switch not to work, and vice versa.
Post Posted: Sat Jul 14, 2012 6:23 pm
thanks fordem have managed to power window up and down by powering the motor direct, its a new master switch so i guess it must be the passenger door switch thats faulty. i have taken it apart and cleaned contacts but no go yet ..will plod on thanks for everybodiy's input..
Users browsing this forum: No registered users and 162 guests
