It is currently Sun Oct 25, 2026 8:39 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3  Next
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Jul 15, 2012 1:17 pm
I have a 2009 Jimny with the ABS so I can only put one battery in the engine bay. I am thinking of replacing the main battery with an Optima D51. The width and length of this battery will be no problem but I am a little concerened about the height. Despite taking lots of measurements and having formed an opinion that it will probably fit it will be quite close so to touching the bonnet so I would like to ask if anyone else has fitted this battery to a Jimny.
The quick search shows a few of this fitted to other cars but not to a Jimny. If anyone has done this I would like to know if there were any issues fitting it. Thanks
Mike
Post Posted: Sun Jul 15, 2012 9:09 pm
My Sierras battery was from a commodore or similar and was a very tight fit.
To save possible bonnet contact I used insulators on the terminals.
Post Posted: Sun Jul 15, 2012 9:12 pm
Post Posted: Sun Jul 15, 2012 9:43 pm
I think that is the battery I have. I just chcuk c piece of ruber over the battery and tuck it front and back.
This battery is great. Runs my winch with no dramas even for a short time with the engine stopped. Runs my Engel overnight with plenty of start capacity the next morning.
Post Posted: Mon Jul 16, 2012 10:07 am
Thanks guys.
Vehicle: On the lookout
Post Posted: Mon Jul 16, 2012 1:47 pm
Mate - good choice on the Optima D51 - you have obviously done your homework. There is an alternative though that might fit better and is possibly an even better battery.
Look up Odyssey batteries, like the Optima yellow tops they do Deep-cycle & starting batteries, have a look at the Odyssey PC1200MJT. Might fit better check out the dimensiosn and measure it up. They offer a few different shapes and sizes too, so they will likely have one that fits like a glove.
Crispy old grand vitara
Post Posted: Mon Jul 16, 2012 9:09 pm
Squibby - Thanks for that. They certainly have quite a range. The PC1200MJT is too wide for the standard spot in my Jimny though. I can only fit up to 130mm without mods and 140mm with some minor cutting. That one is 169mm did you fit that one in your Jimny? What year is yours and did you need to move the fuse box to fit it in?
Mike
Post Posted: Tue Jul 17, 2012 9:20 am
Nah it was for my auxilliary tray and I was mostly concerned about height, forgot about the width. I made a cardboard box to the dimensions of each of the two batteries and checked to see if the box fit first. Might be worth doing. Try out a mock up of the D51 and if you have to drop down from a 41Ah to the next size down...
Post Posted: Tue Jul 17, 2012 7:10 pm
Are these any help to ya?
Found on facebook.
Light Weight Race Battery 16 Volt 425CCA Turbostart
__________________________​__________________________
New Low Profile design is only 6" high, perfect for limited space mounting. At only 32 pounds, TurboStart's light weight 16 volt battery is among the lightest AGM types in the industry. It puts out 425 cold cranking amps at 0°F. Reserve capacity is 48 minutes @25 amps. Part No. TSS16VL
Only $315.00 plus freight!
Free EMA T-Shirt if this ad is mentioned upon purchase!Image
Post Posted: Tue Jul 17, 2012 9:43 pm
Squibby
That was exactly what I was thinking today. I did this to work out where to put the compresor as well.
Chris
That one is a 16 volt battery and does not have the same capacity as the Optima. Don't know how you just come across this stuff though. Facebook? Not the place I would look for a battery.
Mike
Post Posted: Tue Jul 17, 2012 10:09 pm
It found me, I wasn't looking for it, but yes it was Facebook.
Post Posted: Tue Jul 17, 2012 10:34 pm
You need to be careful with AGM batteries. Some will not like being near a hot engine. Its mainly due to the cases not being designed for high temps. When I was researching, I'm pretty sure the Odyssey's fell into this category. Might have changed though. That was over 2 years ago.
Post Posted: Tue Jul 17, 2012 10:35 pm
I think I am going to stay with the Optima at this stage.
Post Posted: Tue Jul 17, 2012 10:43 pm
I had go check them out on ebay.
I think thats what I will get after this battery's demise
Post Posted: Wed Jul 18, 2012 2:54 am
Hmm I found similar dramas so decided to get a 400cca for engine bay and 120ah for rear of car to run all other garbage, my 9500lb winch is hooked to small engine bay battery and struggles a little on a hard uphill winch with say a pootrol or cruiser but apart from that just fine, I use a winch block on the hard pulls and no probs!
Post Posted: Sat Jul 21, 2012 9:31 pm
So I took up Squibby's suggestion and made up a cardboard model of the Optima D51 battery today. It is a perfect fit in the battery tray and I was just a little concerned about the height. I worked out that it is just going to fit.
By the way this seems to be a fuse on the feed from the alternator. Am I right, is this just a fuse or does it serve some other purpose?
Mike
Post Posted: Sun Jul 22, 2012 11:59 am
Looks like it clears from this angle. Worth comparing the D51 with the D51R. The terminals are reversed between the two models. It's a shame the Posi leads won't reach the rear of the battery or you could have the posi nearer the firewall where there is more clearance to the bonnet. It's less critical how close the negative term gets to the bonnet obviously.
Post Posted: Sun Jul 22, 2012 6:44 pm
Good point Squibby. I didn't think of that option. I put some grease on the top of the fake positive terminal and it did not touch the bonnet. I swapped it around and with the terminal closer to the edge it did touch. Where it is now the positive terminal fits inside the bonnet strengthening steelwork. The 51R would be an option though with just a bit of work to lengthen the cables but I am pretty sure it will clear the bonnet where it is now.
Is that last photo just a fuse?
Mike
Post Posted: Sun Jul 22, 2012 6:51 pm
Yes that is a fuse. I did a search, and sx4's and other suzukis have them, too
Post Posted: Sun Jul 22, 2012 7:31 pm
Thanks Chris.
Post Posted: Mon Jul 23, 2012 7:34 am
Mike57 wrote:
...Where it is now the positive terminal fits inside the bonnet strengthening steelwork...
Mike
awesome, that's pretty much how my optima fits in the auxilliary tray, and I've had no problems even without an insulated shroud over the top.
Post Posted: Sat Aug 04, 2012 5:41 pm
I can now confirm that the Optima Yellow Top D51 is a perfect fit for the late model Jimny. You will need to fit new battery terminals but apart from that no clashes and adequate clearance from the Bonnet.
Post Posted: Wed Aug 08, 2012 12:09 pm
Pics or it doesnt exist.... LOL,
nah im interested on seeing final product anyway.
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Aug 08, 2012 1:56 pm
OK, I will take one on the weekend. I took a movie under the bonnet with it closed just to make sure there was clearance and it is fine, but I have never used You tube so I will put up some stills of it with bonnet open. Thanks for looking for a handbook info for me Scales.
Vehicle: 1999 Jimny with to much!
Post Posted: Wed Aug 08, 2012 7:46 pm
Funny isnt it, you look at the spec sheet on the Optima website and it says 500CCA, but all the adds on evilbay say 450CCA?
I wonder who is right?
Post Posted: Wed Aug 08, 2012 10:14 pm
Did not read what it actually said on the battery but I will check that also and post it up. The Optima spec sheet defintely says 500 CCA.
Post Posted: Wed Aug 08, 2012 10:42 pm
That would be great Mike57 as Im just about to buy one of these to power my winch......
Post Posted: Thu Aug 09, 2012 7:15 am
QIK, did some research for you this morning re: battery and winch, deep cycle and winching is bad ju-ju (i suspected this, just wanted to confirm before mouthin off).
the deep cycle is more suited for a continuous low amperage supply to a low charge level then recharged. IE perfect for dual battery and fridge usage for a few days... If used for winching it MAY ruin your nice expensive new battery before its time, and not operate the winch as well as it could either as it would struggle to give up the amps compared to a cranking battery.
A bit of reading i discovered that most winch manufacturers say to use a leadacid battery.
I suggest if you CAN get a dual batt tray made up, or buy one from pirhana... do so. then stick a 2nd Lead acid in there like I have (with a 200amp redarc) and you should have more than enough between the 2 lead-acids to get you out of trouble without having to mess around with alternators or big single batteries. More cost effective also, and less risk to your existing electrics.
as a plus you have a auxilary jump-start setup from this also. and a good power source for your fridge if you ever feel the need to use it.
Id only consider one of these Optima's as my aux battery personally. As Mike hasnt got room for a AUX, its the next best thing i guess. but you have room for one QIK so i'd utilise it.
Post Posted: Thu Aug 09, 2012 12:24 pm
Awesome post, but totally wrong on the last paragraph. The Optima Yellow top IS a Deep Cycle AND starting battery - as discussed above it handles 450 - 500 CCA depending on what specs you read. It's not a regular type of deep cycle. So if you do have to compromise a little and can only fit one type of battery to do both starting(or winching) AND a bit of Deep /Cycle - then the Optima Yellow top is one of the best options.
Thats why the Optima Yellow tops RRP are about twice the price of a simiar AH regular Optima Deep Cycle battery.
Post Posted: Thu Aug 09, 2012 4:51 pm
ah okay, my bad. im not really up-to-date with the optima battery tech.
I still stand by my post though, for QIK he is better off with dual batt's IMO and yeah i guess if you can only have ONE battery the optima would be a go-er if what you say is true. But that would still be a compromise for not being able to have 2 in my eyes.
Users browsing this forum: No registered users and 195 guests
