| Engine hunting when the lights come on. http://auszookers.com/forum/viewtopic.php?f=5&t=34214 |
| Author: | Bruised [ Mon Jul 16, 2012 12:08 pm ] |
| Post subject: | Engine hunting when the lights come on. |
Hi All, My zook (G13BA) is hunting badly when the lights are on, otherwise she idles well with the lights off. Any ideas on the issue? Suggestions appreciated. Cheers Bruised |
| Author: | zukmeista [ Mon Jul 16, 2012 12:18 pm ] |
| Post subject: | Re: Engine hunting when the lights come on. |
Idle-up solenoid is probably cactus. There is a green plug on the side of the manifold, disconnect it and if the idle is good with the lights on that's what the problem is. |
| Author: | want33s [ Mon Jul 16, 2012 12:18 pm ] |
Check the vacuum hoses from the solenoid at the front of the inlet manifold. |
| Author: | Bruised [ Mon Jul 16, 2012 3:55 pm ] |
Idle up Solenoid it is. Pull out the green plug and killed the hunting. Thank you ... |
| Author: | KEENSY85 [ Mon Jul 16, 2012 9:21 pm ] |
u learn somthing every day i allways thought that was called a stop flow solanoid |
| Author: | Reubs [ Mon Jul 16, 2012 9:25 pm ] |
Bruised wrote: Idle up Solenoid it is. Pull out the green plug and killed the hunting. Thank you ... KEENSY85 wrote: u learn somthing every day i allways thought that was called a stop flow solanoid They are 2 different solenoids... The idle-up solenoid is a vacuum switching solenoid that pulls on a vacuum actuator to turn up the throttle when you turn on headlights or a/c. The idle solenoid / stop flow solenoid is there to stop the fuel and the engine running-on when the car is switched off. |
| Author: | KEENSY85 [ Mon Jul 16, 2012 9:37 pm ] |
oh okay i know what u mean the idle up actuator sorry my stupid lol |
