It is currently Mon Aug 03, 2026 8:41 pm
Vehicle: sj 50t
Post Posted: Mon Jul 16, 2012 6:50 pm
what are the 3 wires on the carb for?
im stuck as my car wont idle, its an 85 sj51t
Vehicle: SJ80, SE416
Post Posted: Mon Jul 16, 2012 9:10 pm
Idle solenoid +12V is black with white trace. You need it to idle.
Vehicle: 1985 lwb sierra UTE
just change the solanoid
its slightly dif use a leafy solanoid,im pretty shure it is called a stop flow solanoid it pretty mich does what its called but may do other things as well im not sure some one withe more exsperiance and knoledge maybe able to help,but if u unscrew ur leafy 1 and swap it it should work ok .if not u may have a blockage as bruce said the other day if u swap number four lead with number 1 and pump the acelerator pedal 3 times then turn the key it may unblock the carb
Green? greeeen is nice !
Users browsing this forum: No registered users and 79 guests
